high mounts and passenger pegs??? pics/help needed
Old Jul 20, 2007 | 04:50 AM
andy9743's Avatar
bought a Hawk with remus alum. high mounts.....the passenger pegs were removed, i'd like to put them back on. does anyone have pics of high mounts with pass pegs on? i can't seem to figure out how to make this work. thanks so much in advance
andy
andy9743@aol.com
Old Jul 20, 2007 | 06:20 AM
superbling's Avatar
Without seeing a pic of yours, I don't know if this will work but most simply use longer bolts and spacers to set the peg mounts out past the cans. You can do this yourself by getting some bolts and box aluminum tubing from a home supply store.
Old Jul 28, 2007 | 05:15 AM
andy9743's Avatar
here is a pic of the pipes:
http://s198.photobucket.com/albums/a...t=P6070001.jpg
still thinking that square tubing and longer bolts will work?
thanks
andy
Old Jul 28, 2007 | 06:12 AM
If money is no object you can buy them from any of the companies like Jardine, Leovince, etc that make them. Otherwise, Home depot by me sells hollow aluminum (and also steel) round tubing. All you need are longer bolts and cut a small length (should be @ 2 to 2 1/2") for each bolt to space the pegs out far enough to clear the cans. Hold your pass peg up in place and measure the space. The spacers go between the hangers and the pegs. A bolt supply house will probably your best bet to match up the right bolts. Hope this helps!
Old Jul 28, 2007 | 07:14 AM
andy9743's Avatar
that is a HUGE help!!!! thanks so much to home depot i go!!
Old Jul 28, 2007 | 08:42 AM
Cool hope you find what you need The spacers you get won't be EXACTLY the same as the ones in the pic (mine are from Leovinci) but you can find some stuff to serve the purpose fine. The hole in the center may be a little bigger but once they're tight (and maybe a couple washers if necessary) they'll work fine.
Old Jul 29, 2007 | 06:07 AM
mkimber's Avatar
mkimber is on a distinguished road
Here's some pics of my pegs. They seem to work good but they don't get much use. I've debated taking them off, but I think they would help protect the bike if it ever goes down.
Old Jul 30, 2007 | 09:06 AM
andy9743's Avatar
thanks mkimber did you make them?
Old Jul 30, 2007 | 03:56 PM
mkimber's Avatar
Nope, they came with the Jardines. You could make some pretty easily though.
fz911
Sep 9, 2010 11:19 PM
102dals
Jun 5, 2010 10:24 PM
badassliftedf150
May 1, 2010 11:18 PM
smittyvtf1
Jul 23, 2009 08:28 PM
andy9743
Mar 4, 2009 06:42 AM
