Help removing plastic clips holding the tail section
Old Mar 18, 2013 | 06:20 PM
rogeratdserve's Avatar
rogeratdserve is on a distinguished road
You know those 2 plastic trip clips holding the tail section/rear cowl on? Is there any way to remove and reuse them? My inclination is to yank them off with a pair of side-cuts!
Any help would be much appreciated.
Old Mar 18, 2013 | 06:47 PM
If they have a phillips head in the center carefully turn it out until you can grab the head and pull it out.
If it is just the button fastener then push in the center and you can pull it out. Pull the pin all the way out the reuse the clip
Old Mar 18, 2013 | 06:49 PM
If its what I am thinking, they are kind of like plastic wall anchors. There is a grommet and a kind of peg that goes through it to expand it. Carefully pull the center piece out, I use a thin flathead screwdriver then needlenose. Once displaced, it releases the expanded plastic & therefore the bond.
Not sure if that makes any sense but its a honda thing.
Old Mar 19, 2013 | 06:41 AM
Jack Flash's Avatar
Well take off, eh.
Worst case scenario, if you need to scrap them to get them out, you go into an automotive store, and you can buy some new ones for a few cents a piece.
Old Mar 19, 2013 | 07:35 PM
Yea, I think I'm going to drill them out and replace. I've tried everything. I appreciate the replies.
Old Mar 19, 2013 | 08:25 PM
cybercarl's Avatar
Screwdriver or even fingernails to pull the centre screw out slightly and then use a Snap On Trim tool to remove.
firestorm_girl
Jun 14, 2013 09:45 AM
supermarto
Jan 25, 2013 10:14 AM
smittyvtf1
Nov 4, 2009 10:38 AM
2005Hawk2006
Sep 4, 2006 08:36 PM
murph996
Mar 24, 2005 06:27 PM
