Help! My bar end is jacked! I think... maybe..
Old Sep 16, 2009 | 03:58 PM
Mike996's Avatar
I got some bar ends in the mail today and went to install them.
When i got the bike, the stock right side bar end was missing because previous owner laid the bike down, and never replaced it. I looked over the bar ends, noticed the notch and went to line it up and screw it in.... hmmm the screw they sent isnt long enough.... or is it???
I went to the left side, unscrewed that one and noticed that the threaded portion was much closer to the end of the handlebar than the other side. That one screwed in... but i could only tighten it so far before the whole bar end started spinning. Is this normal?
I rolled back the grip, and some plastic opaque pieces fell out. im guessing from the wreck. i started a screw in the right (damaged) side and tried to pull on the screw a little to get the threads closer to the end of the handlebar like the other side was.
Thats when i ended up with an "oh crap" look on my face. The silver bar inside the handlebar came out, popped out some little retainer ring and a rubber washer out and now i have no idea if i just screwed something up. I pushed the little silver bar back in, but when i tried to get that little retainer ring back on, it doesnt want to fit around the silver bar (there are no notches)
Please see pictures and let me know what i should do. Thanks in advance for any help!
Old Sep 16, 2009 | 05:10 PM
stebbdt's Avatar
COBB Member
Mike, check out this exploded view,( http://fiche.ronayers.com/Index.cfm/...P_BRIDGE_01-05 ) maybe it'll shed some light for ya. Hope it helps, haven't had to pull mine yet so can't give ya any details there other than the whole assembly is actually a vibration damper.
Good luck
Old Sep 17, 2009 | 06:13 PM
Mike996's Avatar
Good luck
Thank you for that, it does help!
I think i figured out that one part is missing. If you look at #8, the beveled part at the right end of the bar isnt there. the bar is just solid at the end. i must be missing about 1/2 inch of the end of #8. THAT must be what the retaining ring clips onto. DOH!
Thank you again, and off to ebay i go!
Old Sep 17, 2009 | 06:52 PM
From your description I'd guess the end of your bar weight is broken off. It usually happens when the bike gets dropped and the bar end hits the ground.
Old Sep 17, 2009 | 06:53 PM
And from looking at the pic that's what looks like happened
Old Sep 18, 2009 | 12:20 AM
Red_Liner740's Avatar
yea they are known to do that...
mine did it on the right too, basically bike goes down, the bar end doesnt break off, the aluminium internals break off with the bar end.
i was lucky that i still had thread left so i just countersunk the bar end deeper so the bolt catches the threads and its been good since.
Old Nov 9, 2010 | 08:03 AM
evines's Avatar
I'm swapping to apex clip-on risers right now, and I "assumed" that I would be able to re-use the stock bar weights. I got the bar-end weight off just fine, but the parts up inside the bar (parts 8,10,11, and 12 in the Ron Ayers fiche) are not coming out of the stock bar. Is there a trick to getting this out? Is mine just stuck?
And then, assuming I can ever get it out, does anybody know if I could re-use the weights in the Apex clip-ons? The Apex clip-on bar is completely hollow.
Old Nov 9, 2010 | 09:48 AM
poppazuti's Avatar
Head Scratcher
You have to take the retaining ring out first, then try feeding the screw back in a little and yanking it out with some pliers. You'll see why you were having a hard time getting it out once it's out.
They should be reusable if the new bars are the same diameter (7/8" I believe).
Old Nov 9, 2010 | 04:29 PM
evines's Avatar
Thanks. I got the weights out. I couldn't get the clip out, so I pulled really hard and lubed it up, and the whole thing popped out in one piece (weight and all). And it fit in the Apex bars perfectly.
j shizzy wizzy
Aug 10, 2013 04:00 PM
herbvtr1000f
May 17, 2012 02:26 PM
Gerrit
Sep 1, 2008 09:48 AM
Randman
Feb 3, 2006 10:40 AM
