Helibars vs Apex?
Old Mar 1, 2011 | 06:28 PM
CrankenFine's Avatar
Helibars vs Apex?
Has anyone tried Apex brand riser clipons? I saw Helibar recently re-introduced their VTR1000 clipons and I was going to order a set. But I came upon a type I've never heard of before yesterday -Apex. http://www.apexmfg.com/riser.htm They're about a $100 less, and appear to have a lot of adjustability engineered in.
Appreciate any insights, I've only had my S-hawk a few days, but my first couple rides indicate a need for a slightly higher bar position. (along with mirrors that stick out a bit further) But the ride rocks even as-is!
Old Mar 1, 2011 | 08:27 PM
Looks like they only have 50 & 53mm available.
Old Mar 1, 2011 | 09:11 PM
I have apex risers and they are great, but I have a CBR1000 front end that they attach to.
Old Mar 2, 2011 | 03:44 AM
No fit apparently
I did not check out that aspect. I thought about measuring the tubes but forgot to do that before posting my question. Thanks.
Old Mar 2, 2011 | 07:30 AM
Mike Heffernan's Avatar
Mike Heffernan is on a distinguished road
Go straight to Apex's web site, apexmfg.com. They have 41-50mm diameters available, but it is a $30 upcharge for a "special order." I have them with a swapped front end and they are very nice.
Old Mar 2, 2011 | 01:37 PM
Thanks for the additional info.
Old Jun 22, 2011 | 08:05 AM
Tormoz's Avatar
Tormoz is on a distinguished road
Apex clipons
Did you ever end up getting these? I'm considering them. I emailed Apex, btw, and they said I'd need the 41mm clamp size.
Old Jun 22, 2011 | 08:26 AM
I have apex on one vtr and heli on the other. Apex are way more versatile. If I had to buy bars now it would only be apex. Got them right from apex.com or whatever their website is.
Old Jun 22, 2011 | 08:54 AM
Tormoz's Avatar
Thanks! Do you recall, does 41mm sound right? I'll measure when I get home to be sure.
Old Jun 22, 2011 | 10:08 AM
41mm is correct for a stock front end.....
Old Jun 22, 2011 | 11:17 AM
mcg's Avatar
mcg
mcg is on a distinguished road
Installed Genmar risers the other day...definate improvement 3/4 rise over stock.
Old Jun 22, 2011 | 04:28 PM
I'm wondering what the difference is. Since you have both, can you describe? My Heli's hit the hi beam switch at full lock on the fairing, so you can't go any higher, or so I thought???
Old Jun 23, 2011 | 04:01 AM
triplespeed's Avatar
triplespeed is on a distinguished road
Q: do you have the old or new Helibars design?
Old Jun 23, 2011 | 07:15 AM
I think they are older helis. They give a rise and can be mounted above or below the triples. The apex can slide up & down for hieght and adjust for and hand angle. (so are way better). I also had a set of vfr bars which are a nice way to raise the bars with stock forks.
Old Jun 23, 2011 | 10:51 AM
racer187x's Avatar
racer187x is on a distinguished road
I haven't had the stock bars off the bike yet. Do they have locating holes in them for the various instruments on the bars? If so, do the heli's have those locating holes as well? What do you do with the Apex bars if some of the instruments have locating tabs on them?
Old Jun 25, 2011 | 04:13 PM
3Dcycle's Avatar
3Dcycle is on a distinguished road
i went taboo on the tabs and filed them off. everything fits tight and does not turn. exept for the left light switch and a few layers of elec. tape fixed that. i did that because i want to retain the adjustablity that i paid for.
other than than i love the bars i slam my thumb tween the tank and bars on both sides when i forget its so close. but only doing that in the drive way or parking lots so not a big deal.
I have 400 miles with them and 400 w/ stockers the apex way better and next weekend im doing a 2-3k ride so will let you know how they work.
Old Jun 25, 2011 | 04:23 PM
Drill locating holes.... it is actually pretty easy.
mikstr
Aug 9, 2011 06:04 AM
3Dcycle
Jul 29, 2011 07:51 PM
___RC51___
May 19, 2011 09:22 PM
smokinjoe73
Oct 22, 2010 08:49 PM
selztoad
Feb 28, 2009 09:43 AM
