headlights keep blowing
Old Jul 7, 2015 | 09:19 PM
  #91
cccolin's Avatar
cccolin is on a distinguished road
I'm guessing that you did the coil test while they were cool? Maybe next time the bike displays its bad/hot behaviour you could yank a spare plug from your pocket, hook it to the front spark plug lead and see if you are still getting a decent spark?
no, they were hot. I had run it for a bit. and yep, i plan on doing that.
Old Jul 7, 2015 | 10:07 PM
  #92
cccolin's Avatar
Thanks again for the help!
Old Jul 8, 2015 | 12:28 PM
  #93
cccolin's Avatar
Ok. it is, in fact, not sparking when it does the stutter and die thing. I just went and rode around for a while with a spark plug in my pocket, since I can't seem to get it to do it when it's in my shop. jumped off and tested the spark and...whaddya know. no spark. let it sit for a few minutes....voila, spark again. rode it until it happened again, same thing. If I revved the throttle, I could get it to start and run on the rear cylinder randomly, but the front still wasn't sparking.
so this is the cycle: starts fine. ride it for a few minutes, stutter on one cylinder and die, no spark. let it sit for a few minutes, the spark comes back and it will run again. a few minutes later, it dies again. it seems to happen when the temp guage is around halfway.
definitely electrical. I really have no idea at this point other than a short in the harness or something having to do with the temp sensor.
Old Jul 8, 2015 | 08:56 PM
  #94
scottiemann's Avatar
not sure if possible but have you tried running it with temp sensor unplugged?
Old Jul 8, 2015 | 09:03 PM
  #95
cccolin's Avatar
I have not. A very very very nice fellow is sending me a spare set of coils to test. I did find some info suggesting that coils and/or CDI failing only when hot is pretty common.
Old Jul 8, 2015 | 09:08 PM
  #96
I would guess the cdi in this circumstance...
Old Jul 8, 2015 | 10:18 PM
  #97
mwkeats's Avatar
mwkeats is on a distinguished road
Hi There,
I'd check the pulse generator before replacing the other parts. Being that it is inside the engine, it experiences a greater change in temp than the external ignition units.
For what it's worth, I've replaced the connector behind the LHS radiator with a sealed one to keep the crap out of this connection.
Old Jul 9, 2015 | 08:10 AM
  #98
cccolin's Avatar
Originally Posted by mwkeats
Hi There,
thanks, i'lll look into that.
Old Jul 9, 2015 | 07:06 PM
  #99
Cadbury64's Avatar
VTR virgin
I think there's a method using a timing light to check this one in the manual.
Old Jul 9, 2015 | 07:21 PM
  #100
cccolin's Avatar
not really. All you can do with the timing light is see if the timing is correct. if it's not, you can't adjust it, and it doesnt tell you if it's the sensor or the cdi or coils. there's another test in there to see if the sensor has the right voltage.
Old Jul 11, 2015 | 10:19 PM
  #101
cccolin's Avatar
okie dokie, new update. an extraordinarily helpful forumite sent me a spare pair of coils to test on the bike. I put them on, went for a short test ride, all seemed well. put on my gear, went for a good 20 minute ride, all was well. come to a stop about a mile from my house, and it did the stutter and die thing again. ARGh. the weird thing is, it did it much milder than before. and it's been taking longer and longer for it to happen. it's almost making me think there's a clog in the carb somewhere that is working itself out.
Old Jul 13, 2015 | 09:27 PM
  #102
cccolin's Avatar
finally got around to testing the pulse generator, which appears to be the issue. crossing fingers.
Old Aug 25, 2015 | 06:31 PM
  #103
cccolin's Avatar
ok, so after a 25 day road trip through the rockies and a few other things that have kept me from the bike, I finally have the pulse generator on the way, have rebuilt the carbs yet again to put them back to the settings they were on when i got it, which worked nicely....so cross yr fingers for me, and stay tuned. Hopefully I can have it running again this weekend.
Old Aug 27, 2015 | 12:24 PM
  #104
Hangfly's Avatar
If you have not done so already, temporarily jumper out the kickstand switch to see if that is the problem. Or just buy a replacement on Ebay. I found a low mileage unit for $20.
Old Aug 27, 2015 | 12:25 PM
  #105
cccolin's Avatar
I already did that, it wasn't the problem. thanks though.
Old Aug 27, 2015 | 12:33 PM
  #106
Hangfly's Avatar
OK, I admit that i did not read all the posts.
My kickstand switch would open when the exhaust heated it. Many times it occurred while waiting at a light.
I believe there are two contacts. one for the ECU, and one for the light.
Make sure you jump out the one to the ECU.
It's easiest to chop the cord and strip the wires.
Old Sep 4, 2015 | 06:18 PM
  #107
cccolin's Avatar
edit. nope. still doesn't work.
Old Sep 6, 2015 | 05:52 PM
  #108
cccolin's Avatar
oooook. turns out, it was actually a fueling issue. combo of two things: the petcock diaphragm was bad, and the vent tube was clogged, so the tank was getting a vaccuum lock and not letting any fuel out. I had checked the petcock and it seemed fine, but I went ahead and replaced the diaphragm anyway, and it quit doing the stutter and stall out thing. it's still a bit choppy right off of idle, I'm thinking the vaccuum vent isn't entirely cleared out, and/or whatever gunk was clogging it is also in the pilot jets.
Old Sep 6, 2015 | 06:25 PM
  #109
bird-rider's Avatar
bird-rider is on a distinguished road
Had the same issue recently. I thought it was a electrical malfunction but turned it was a clog fueling system. Good thing a pal of mine who works from 4 Wheel Online lend me a hand on finding the problem. It was just a 10 mins diagnosis and job for him.
Old Sep 12, 2015 | 04:19 PM
  #110
cccolin's Avatar
so, I converted my petcock to a manual one and the problem seems to have disappeared entirely. crossing fingers.
McFixxx
Jun 4, 2011 08:32 PM
thefauxnarchist
Nov 28, 2008 10:18 AM
superchicken_on_roids
Sep 26, 2008 05:37 AM
Tonyizcool1
Aug 15, 2008 05:49 AM
jbake
Apr 18, 2006 11:47 PM
