Headlights keep blowing
Old Aug 13, 2008 | 12:36 PM
Tonyizcool1's Avatar
Tonyizcool1 is on a distinguished road
My headlights blew last night, so I went to the store and got a new one same kind, and it lasted about 30 minutes and then it blew too. What the heck is going on? Anyone have any ideas? Also my fan for the radiator is only working half the time now. I checked the fuses earlier and they all look good.
The bike starts right up and runs fine and all the other lights are working.
Old Aug 13, 2008 | 12:41 PM
superbling's Avatar
Check your voltage at the battery with the motor at idle speed and 5k rpm and let us know.
Old Aug 13, 2008 | 12:49 PM
bad R/R
Old Aug 13, 2008 | 01:23 PM
Hotbrakes's Avatar
Sounds like the R/R.
Old Aug 13, 2008 | 01:39 PM
SuperMike's Avatar
SuperMike is on a distinguished road
I had the same problem when I bought my 98. I was furious when the $22 silverstar blew. I did the R6 R/R replacement that is posted on the forum. Plus when I installed the new bulb I took extra care not to touch the blub with my bare hand as they say the oil can cause problems. I did these things and have not lost another bulb since. Also interesting is that I was having trouble with my fan too. That has resolved as well. I noticed when i was riding that sometimes the headlight would seem brighter than other times. It was like the power would surge through the system. You should do the check that superbling mentioned to confirm.
Old Aug 13, 2008 | 01:45 PM
filter69's Avatar
Thats Mr Dill hole to you
Yup sounds alot like R/R
Or you gonna have to start feathering your wheelies down when you see the cops.
yeah I will see about getting my hands on a multimeter.
Old Aug 13, 2008 | 01:47 PM
Shoot they just started charging bikers that wheelie $1,000 fine now. I can't afford to risk getting caught doing a wheelie.
Old Aug 13, 2008 | 03:27 PM
filter69's Avatar
HOLY SH*T 1 grand i would MOVE NS no matter what i do around here cept run from the police its 104 bucks ! and you can get as many speeding tickets you want it doesnt count as a moving violation here in SD (granted they are f'in spendy thou)
i got caught ridin one a month ago and i just went ahead and ran it out to the end of the block while the police was blarin the horn at me .. hehehe pissed him off a bit but still it was 104 bucks not like it goes up by the feet
Old Aug 13, 2008 | 05:04 PM
Ok I tested the volts.
1st test: 13.4v with the bike off and 17.8v when running at idle and throughout the rpm range.
2nd test after riding for a bit: 13.6v when off and 14.8v when running throughout the rpm range.
Does this help anyones diagnostic?
Old Aug 13, 2008 | 06:00 PM
Anto's Avatar
Anto is on a distinguished road
dear god
17.8 volts
RR is toast, maybe your battery as well
Old Aug 13, 2008 | 06:01 PM
superbling's Avatar
It should be 15.5v MAX!
Your r/r (regulator rectifier) is bad. Stop running the bike as it can do more damage. Hopefully your battery is still OK.
TONS of info on r/r's here. Welcome to the club (mine was 18v).
Old Aug 13, 2008 | 06:04 PM
I have to ride it a few miles tomorrow, it is going in the shop for an oil change and tune. I called them about the r/r and they said it would be 170 freaking bucks. Dennis kirk has one for 100, should I buy one like this or convert it to a different brand one?
Old Aug 13, 2008 | 06:56 PM
filter69's Avatar
Convert convert convert ....
And if ya wanna take a chance there some stockers of questinable origin on ebay for like 30 bucks..........Caveat emptor
heres the link
http://cgi.ebay.com/ebaymotors/NEW-V...=1218680059077
Old Aug 13, 2008 | 06:59 PM
superbling's Avatar
Well if you have to, you have to. Run the high beam the whole time. DK isn't going to be the Honda item but you probably know that. It will be plug and play tho'.
Using yamaha r1/r6 or gixxer units are popular mods because they last and much cheaper used but require splicing or re-wiring. Look in the knowledge base forum for how-to's.
Good luck.
Old Aug 13, 2008 | 07:13 PM
thanks. I will look around for one. If I go with a Honda one I will certainly get one with fins.
Old Aug 15, 2008 | 05:49 AM
Ok I am pretty sure the battery is fried. Smelled like rotten eggs and then was dead this morning. I have a new RR coming in today, will go buy a new battery later. Hopefully this will fix my electrical problems. Thanks guys for your input.
cccolin
Sep 12, 2015 04:19 PM
McFixxx
Jun 4, 2011 08:32 PM
thefauxnarchist
Nov 28, 2008 10:18 AM
superchicken_on_roids
Sep 26, 2008 05:37 AM
jbake
Apr 18, 2006 11:47 PM
