Have an Ohlins? I need a small favor...
Old Mar 23, 2015 | 06:23 PM
Could someone please snap a quick pic of the remote preload bracket next to a ruler? I'm about to buy a small piece of carbon to make myself one. When I bought the O, it didn't come with a mount, so I just used what I had laying around.
Just lookin' for the original design, not your custom one off. TIA!!
And how thin of a piece would you guess I could use? 5/32 is their thickest at the present time.
Old Mar 23, 2015 | 06:47 PM
Hope these are what you need Sorry for the crappy quality it's dark in the garage and I was in a rush. That one is 3/16" thick (aluminum), but I don't see why 1/8" wouldn't be more than enough-my LeoVince exhaust brackets are only 1/8" thick (yes they're the originals) and they're more than enough to support the exhaust and this weighs next to nothing. Again I'm talking aluminum...you did say carbon fiber... 5/32" is right in-between those 2 thicknesses and I'm sure will be fine in carbon fiber to support this, again it's really light.
Attached Thumbnails Have an Ohlins? I need a small favor...-1.jpg   Have an Ohlins? I need a small favor...-2.jpg   Have an Ohlins? I need a small favor...-3.jpg
Old Mar 23, 2015 | 07:01 PM
Perfect Cap!! Thank you kindly. Going to buy the 5/32 piece.
Old Mar 23, 2015 | 07:04 PM
I've never worked carbon. Any advice on drilling holes in it or cutting curves?
Old Mar 23, 2015 | 07:11 PM
thedeatons's Avatar
Stabdard drill bits are fine. If you're shaping it with a dremel or a flap disc wheel there will be lots of dust, so wear a mask in that instance.
James
Old Mar 23, 2015 | 07:25 PM
James
Unibits are your friend with CF and fiberglass. Harbor frieght has some for very cheap ($12) for a set of three. They won't split or crack the piece like standard bits can do when they pop through.
And like James said, make sure you wear a mask! You don't want those fibers inside you.
Old Mar 23, 2015 | 09:36 PM
You bet, glad I could help. I can also trace it and fax it if you like (or you could just trace the screen too if you can get the size right).
Hawkrider
May 24, 2012 05:21 AM
inderocker
May 14, 2011 07:01 PM
uchi
Apr 28, 2010 08:09 AM
Just_Nick
Nov 3, 2009 07:42 PM
Verne
Mar 11, 2008 02:19 PM
