Gas Light comes on at 80 miles!??
Old Jun 28, 2011 | 06:01 AM
  #31
3amta3's Avatar
Jack of all Master of non
3amta3 is on a distinguished road
i get 120-135 on average right now but i am just trying to tweak it to get a little more.. i too give it hell once and a while but for the most part it is my daily driver to and from work and that is it.
i just synced my carbs two weeks ago to check them and it was spot on. i have not gotten into my valves yet, i am going to rip the engien out of the bike next month and go ove rthe valves and change the clutch out. once it is back together i will sync the carbs again. since i stil have a ratttle durring a load i am thinking of just doing this for prevent maint. that and my clutch has a bit of a vibe to it.
yes talking about this stopped me from spending un-needed money on something i dont need, so thank you guys for setting me straight on that.
Old Jun 28, 2011 | 06:56 AM
  #32
insider's Avatar
insider is on a distinguished road
Originally Posted by Luco
I don't want to sound like a jerk here, but I keep reading about the gas mileage you guys get and I'm shocked. I'm not hard on the throttle by any means on average(i usually shift at 3500), but I do give it **** every now and then. And I regularly get anywhere from 120-140 miles per tank
as somebody already stated, it depends where you make that mileage (town,outside),and even if it's town,it depends on the traffic....there are a lot of factors which dictate the fuel consumption,not just flooring it....
Old Jun 28, 2011 | 07:46 AM
  #33
3amta3's Avatar
i have a 60 mile round trip to work and back.... about 40 of it is freeway 55-70 MPH and the rest is 45-55 MPH
on the freeway i hit 4000-4300 RPM i want to drop that down to about 3500- 3800 on the freeway
Old Jun 28, 2011 | 08:58 AM
  #34
That sounds reasonable. I tend to ride lower in the RPM's as well (probably too low for the sportier riders here)
You can play with your gearing here:
Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
Just put in the bike info, and play with the final drive ratio- it uses the teeth count of front and rear gears
Old Jun 28, 2011 | 09:14 AM
  #35
3amta3's Avatar
i am all about saving gas..... i'll drop a tooth in the back and see what it does for me. but i guess either way 40-45 mpg is not that bad after all.
niteridder64
Jun 17, 2012 03:12 PM
nuhawk
Jul 28, 2010 09:00 AM
nuhawk
Dec 24, 2009 02:42 PM
NWbrew
May 27, 2009 04:19 PM
nuhawk
Oct 25, 2006 08:35 AM
