Gas Light comes on at 80 miles!??
Old Jun 26, 2011 | 11:51 AM
johnpace2's Avatar
johnpace2 is on a distinguished road
Hey Guys,
My RLOD is coming on at about 80 miles. I don't beleive I ride the bike particularly hard (sort of a n00b anyway) and I'm usually about 4-5K rpms. My average rides are about 50 miles with not a ton of twisties.
What are some potential reasons for such bad mileage?
Thanks!
John
Old Jun 26, 2011 | 11:56 AM
Someone could have tried to jet the carbs and set them way too rich or one/ both of the enrichment cables (or choke) might be stuck or improperly installed.
Old Jun 26, 2011 | 12:06 PM
johnpace2's Avatar
I figured that it may be carb related, but the bike seems to run fine... Then again, I don't have a lot to compare it to...
When I got the bike last fall, I had the APE cct's installed and during that process, it was discovered that the forward cylinder valves were screwy so it has fresh valves from a reputable shop. No idea if that has any impact, but I thought I'd mention it...
Old Jun 26, 2011 | 12:19 PM
mcg's Avatar
mcg
mcg is on a distinguished road
Same story
Mine may be jetted rich as it will idle with choke off immediately after starting... In city 11 litres/140kms. Have not had a highway trip yet so cruise performance is unknown.
Old Jun 26, 2011 | 05:27 PM
80 miles is not bad if you are in the city. The diff between city and hiway riding in huge on this bike. Mine comes on at 70 something (all city) and 90+ hiway. I dont baby it though. (not that I hammer it either).
Old Jun 26, 2011 | 05:38 PM
3amta3's Avatar
Jack of all Master of non
3amta3 is on a distinguished road
man i get 100-130 doing half highway and half city. i thought i was doing bad, i guess i am doing alright then.. i am going to change my drive gears from stock 16f and 41r to a 520 conversion at 15f to 43r . that should give me more drive out of my gears and help with the fuel economy. it puts the gear ratio around 2.83 which is at the top of the power to fuel curve.
Old Jun 26, 2011 | 05:57 PM
You might want to do a search on that topic because you couldn't be more wrong.......
Old Jun 26, 2011 | 06:05 PM
3amta3's Avatar
i did check.... if i go any higher on the ratio it would be bad for what i am doing.... this is optimal ratio
Old Jun 26, 2011 | 07:41 PM
15/43 is quite a bit lower than stock gearing. -1/+2
Old Jun 26, 2011 | 08:08 PM
Maybe for some unique application but to call it a optimal ratio is rather silly as all you have done is remove 6th gear from the stock set up and made 1st gear all but unusable.
So what facts do you have to support your opinion or are you just parroting something you read somewhere.
Old Jun 26, 2011 | 08:55 PM
Oh boy, lets talk gearing.
Go ahead and try that gearing but I will bet you dont like it. Its too short & you will be reving the heck out of it and shifting twice as often. I would recomend dropping one tooth up front & work up slowly from there unless you plan on stunting. (which I would also advise against)
Old Jun 27, 2011 | 02:32 AM
3amta3's Avatar
stock gear ratio is 2.56 with a 16-41
with a 15-43 the gear ratio will be 2.87
that makes it a lower gear ratio and works just opposite what you guys are talking about. 1st gear will be better used as we as the rest of the gears.
Old Jun 27, 2011 | 03:58 AM
CrankenFine's Avatar
Old Jun 27, 2011 | 05:38 AM
You're raising the gear ratio that much to help with your fuel economy?
Old Jun 27, 2011 | 06:40 AM
Stevebis1's Avatar
Hmmm... sounds like 3AMTA3 should work for sumofallparts on Ebay - they seem to think 15-43 even corrects speedometer error!
I run 16-43 and cannot open the throttle fully in 1st without lofting the front wheel. That's not to say there aren't a number of members here that like it, but regardless it is NOT going to improve mileage
Old Jun 27, 2011 | 07:16 AM
3amta3's Avatar
ok well obviously i have been going the wrong way with my reseach. what would give me better gas milege because that is all i wish to do. i am not a track rider at all, so a 2.5 to a 2.8 will not help me in this respect?
stevebis1:
what sort of gas milege do you get with a 16/43?
Old Jun 27, 2011 | 07:19 AM
Crankenfine, THAT is a funny response; I didnt know about that thing. Hey 3amta, it makes it way shorter=more revs=worse mileage.
To avoid the usual fireworks on this subject I am stating my findings on this bike. I ride almost only city riding, have been racing 11 years and ridden over 240k miles on the street year round.
15-43 is really low especially on a torque monster like the VTR. Even in NYC you have to shift every 2.3 nanoseconds to the point where you cant get decent drives. On an atv a stump-puller first gear may be useful, but unless you want to tow trailers around your yard its useless on a sport bike.
I have the advantage of have 2 hawks so I get to ride different gearing back to back & the only one I found useful was 15-41 (one tooth down in front). More pull but useable.
YMMV.
Old Jun 27, 2011 | 07:35 AM
b1m3x8's Avatar
b1m3x8 is on a distinguished road
I get 80 mile RLOD all the time, but I need to lay off the trottle a little bit. Plus some of the gas stations with those annoying nossles that you need to hold back never let me fill all the way up.
Old Jun 27, 2011 | 07:56 AM
Hey B1m, how could you have not bought SEVERAL of these https://www.superhawkforum.com/forum...le-tool-24466/
I bought 2 and they really help. I wont leave home without one.
Old Jun 27, 2011 | 08:08 AM
geekonamotorcycle's Avatar
ruh oh did someone say gearing change? lol
I have on occasion gotten 80 miles to Orange light. It is mostly when I do some city riding or am riding in a spirited group orrr if I leave my choke on.
This weekend I learned many things about carbs and chokes. It is possible that a critical part of the choke system broken when a gust of wind blew on her. so you may want to check it out. Look for my carb thread that I started 2 days ago. there is nothing at all difficult about pulling them out and cleaning them. You only need a small assortment of hand tools and about 2 hours.
https://www.superhawkforum.com/forum...-stream-25991/
Old Jun 27, 2011 | 08:32 AM
Stevebis1's Avatar
stevebis1:
I'm not sure my results will directly compare with yours. There are a number of threads around where people have listed their gas mileage and I tend to be in the upper range. As others have pointed out carburator tune and type of riding are big impactors.
I can tell you that I when I switched from 16-41 to 16-43 the mileage drop was minor. My biggest impact occured when I went to an electric water pump. I did that along with a +4 advancer at the same time and saw a very consistent 5% bump.
Old Jun 27, 2011 | 10:18 AM
I guess you're going to explain gearing to us now. Here is a couple things to read and then you can get back to us.
But i must say hearing that 15\43 will improve fuel economy is one of the funniest things I have heard in quite a while.
https://www.superhawkforum.com/forum...eration-24786/
https://www.superhawkforum.com/forum...day-wow-25182/
So what were we talking about again...... Name:  popcorn2.gif
Old Jun 27, 2011 | 10:21 AM
b1m3x8's Avatar
I remember reading that thread awhile ago, Thanks I'll pick some up.
Old Jun 27, 2011 | 10:50 AM
3amta3's Avatar
i am here for everyones laughter. i was just going from what i read. thats what i get for going to school....
Old Jun 27, 2011 | 11:01 AM
3amta3's Avatar
ok so if i go to a 40t back i should be better.. do they make 17 front for this bike?
Old Jun 27, 2011 | 11:30 AM
So wait, 3amta, you havent done the gearing swaps, you just (allegedly) read about them? OK, terrific.
Old Jun 27, 2011 | 11:54 AM
I haven't seen 17/40... That may help at higher speed freeway, but you won't get any better mileage in town (if you're riding in 6th in town right now you're lugging it already which is hard on the motor and isn't as efficient)...
This is total guesswork on my part, but like others have said you may want to look into other fuel consumption tricks.
You running a stock air filter? Do you know how your carbs are tuned at all... including fuel adjustment screw settings and if they've been sync'd? How high is your idle set? Tire pressure been looked at? How many wheelies do you pull from stoplights?
Just ideas that I'm throwing out there. B/C you were in the valve heads recently and did some changes, there's a good chance that your carbs aren't sync'd as well as they could be.
Old Jun 28, 2011 | 03:21 AM
insider's Avatar
insider is on a distinguished road
fuel economy is a sensitive subject for me as well as it spoils all the fun with this bike,for me.
i've recently done some tests. Filled her up twice,only city traffic.
First time light came out after 129 km (80 miles), second time at 128 km (80 miles and so).
Fuel tank is 16L and reserve is 2.65 L if I'm not mistaking. So basically I've used 16-2.65=13.35 L for 129/128 (80 miles) of city traffic. That would be a 10.4L per 100km in-town. Which is f**ed up.
I've only tested it once,and not to accurate outside city, going 100-170-180 km/h and i got 6.8 L/100km I think.
Next test after I heal my hand up will be out of city consumption at various constant speeds. I'll test to see how much it takes at 120-130 km/h and how much at 140-160 km/h, to find which is the most fuel efficient cruise speed.
I also mention that I didn't hammer it in town to get 10.4L ....
I will also change the spark plugs and sync & clean the carbs,a sat this point my bike is dead between 4.800 RPM and 5500 RPM and I m going mad not knowing WHY.
I am really thinking of getting a SV 1000 N. I think that should get 5.5-6 at cruise speed (130 km ~ so) and 7-8 tops in town,decent abuse..
Old Jun 28, 2011 | 04:39 AM
Sooner or later we all get something bass ackwards. At least the guys here hopefully saved you some $$ on a fuel economy fix that would have backfired.
Old Jun 28, 2011 | 05:01 AM
Luco's Avatar
Luco is on a distinguished road
I don't want to sound like a jerk here, but I keep reading about the gas mileage you guys get and I'm shocked. I'm not hard on the throttle by any means on average(i usually shift at 3500), but I do give it **** every now and then. And I regularly get anywhere from 120-140 miles per tank
