"CrampBusters" = dangerous
Old Jul 12, 2009 | 06:54 PM
BluStreak's Avatar
Fellow Hawksters, just wanna share had a couple of real scary incidences with this little device today. While riding some local twisties, was on approach to a sharp corner and so was downshifting/ braking..... If you have one of these little jewels, you know they wrap around the right side of your throttle grip - the idea being that you can control your throttle with the right heel of your hand, rather than wrapping your hand around it and cramping up after some time. I have an average size hand, but have found that to pop the throttle to downshift (and not be manipulating the 'Buster'), you gotta have your hand shifted to the left side of the grip. Long and short of it is that I ended up taking 2 minor (thank you God) outside corner excursions as a result of inadvertently goosing the throttle with part of my hand that was not intended to be part of my manuver. Took the CrampBuster off as soon as I got home!
Make sure you have your throttle hand very precisely positioned if your gonna leave your "Buster" on, or you might find your self busting off the road.........
Old Jul 13, 2009 | 04:48 AM
No, the cramp buster is not dangerous... However your usage of it might bee... It's definetly not supposed to be used in any way while riding the twisties... That's not the fault of the manufacturer or product... That's just common sense, plain an simple...
Old Jul 13, 2009 | 05:35 AM
cheapbastard's Avatar
cheapbastard is on a distinguished road
I agree, I just used one for my entire cross country trip, and loved it, had no problems with it.
Old Jul 13, 2009 | 07:26 AM
comedo's Avatar
It's a great device but I only use it on trips when I'm going to be cruising on highways at more than 100 kph for more than two hours at a time. When I'm off major highways, I just rotate mine to about a one o'clock position when looking at the end of the twistgrip so that it's out of the way. You also have to be careful making tight turns to the right when it's in the standard position. The crampbuster can contact the tank and open the throttle more than you want.
Old Jul 13, 2009 | 08:44 AM
badboyrr's Avatar
I
Old Jul 13, 2009 | 08:47 AM
badboyrr's Avatar
Angry
I was saying, I only use mine on trips. I have had a moment when I did not remove it and had a incident in the twisties like yourself.
Originally Posted by badboyrr
I
Old Jul 14, 2009 | 05:25 AM
BluStreak's Avatar
Experience is a great teacher............
Amen
Old Jul 14, 2009 | 05:15 PM
Hotbrakes's Avatar
I've got one and its useless. It usually ends up rotating downwards too far to be beneficial so I spend more time chasing it around trying to get it set right.
For $10 more you can get a throttle lock that is great for freeing up the throttle hand for a minute or 2 or more if you're on flat ground.
Old Jul 14, 2009 | 10:51 PM
CentralCoaster's Avatar
While we're on the subject, the throttlemeister is a bit dangerous too. Its hard to not nudge it occasionally in the twisties and then a some point it begins holding the throttle open unexpectedly while heading into a turn. Now I check it on the straights every 10 min or so to make sure its disengaged all the way. It would be kinda a bitch to remove before each twisty ride, unlike the crapbuster.
Old Jul 15, 2009 | 05:39 AM
cliby's Avatar
there is a trade off with most of them. Personally, its hard to improve on the vista-cruise design - cheap, a snap to install and easiest to use and very effective - not as pretty but does its job very well and doesn't get in the way.
Old Jul 15, 2009 | 09:46 AM
Dan Cronin's Avatar
<You also have to be careful making tight turns to the right when it's in the standard position. The crampbuster can contact the tank and open the throttle more than you want. >
Wow. That'll wake you up.
Old Jul 15, 2009 | 10:36 AM
autoteach's Avatar
the vista cruise will contact the tank as well. Not cool (can leave a dent if you are not careful). significantly decreases lock (problem in parking lots)
8541Hawk
Jun 7, 2012 08:46 PM
RWhisen
Oct 16, 2010 07:34 PM
Whoa Nelly!
Apr 2, 2010 04:18 PM
BooYeah
Aug 6, 2005 09:39 PM
L8RGYZ
May 29, 2005 12:14 AM
