Cracked case
Old Aug 24, 2020 | 11:23 AM
Smokeys81's Avatar
Smokeys81 is on a distinguished road
Cracked case
After I replaced my chain it came off as I was riding. It cracked and broke off the brackets the bolts that hold the front sprocket and hydraulic clutch housing. How would you go about repairing this. The clutch will not work because the bolts held everything in position. Lost on what I should do. Any help would be greatly appreciated thank you
Old Aug 24, 2020 | 12:02 PM
ACE VenTRa's Avatar
A few more photos looking straight on would be good.
Old Aug 24, 2020 | 02:41 PM
Smokeys81's Avatar
Here are more pictures after I pulled it apart. This is a very clean bike with just over 18k on it I hope I can save it. Any suggestions or direction to go would be greatly appreciated thank you.
Old Aug 24, 2020 | 03:03 PM
ACE VenTRa's Avatar
From where I sit you have a few options:
$ JB Weld
$$ Tig Weld
$$$ New lower case
I know what I would do and that would be JB unless you know a talented tig welder. Make sure you clean the surfaces thoroughly and mix the JB well and correctly. On the other hand, It is a good opportunity to get a second block and rebuild an even more kickass motor.
If it comes down to choice there is at lease one forum member than supply most if not all of what you need.
AV
Old Aug 24, 2020 | 04:24 PM
Would you really trust JB Weld on that? I don't know I've just never had the greatest luck with it on anything that mattered... I don't see why it should be a big deal to have tig welded. Just don't take it to some muffler shop. Find something along the lines of a custom car shop that tigs frames and roll cages or custom headers, etc... i.e. someone who knows what they're doing.
Old Aug 24, 2020 | 04:32 PM
ACE VenTRa's Avatar
The covers on my S4 and CBR are plastic...I'd JB in a sec. the location is the hard part for getting it tigged--that and the contamination from grease makes it difficult to make a decent weld.
...just my 2 rupees of advice.
AV
Old Aug 24, 2020 | 06:44 PM
At today's rates, that's closer to 3 cents, but I get your meaning.
Old Aug 25, 2020 | 05:43 PM
That sucks. I wouldn't JB it. It'll be a long drawn out mess to get the material in place to set up, then it'll end up failing on you. W/ rubber bits in close proximity, welding might not be feasible either. I think you're looking at a new case 1/2.
Old Aug 25, 2020 | 06:30 PM
ACE VenTRa's Avatar
Upper and lower case are numbered and matched based on crank bore...if you get a lower you need a matched upper.
AV
Old Aug 26, 2020 | 04:47 AM
Can it be repaired? Yes.
WIll you find a local skilled welder to do it? Maybe, will they require the parts to be welded to be clean, oil free, not assembled with oil seals, gaskets in them at or near the are to be welded? Likely. Will that welder want the part to be welded on their bench? Likely.
At some point a $100 set of Ebay cases that you transfer your good motor internals into is a good idea......but alas I could never do JUST that , so add new bearings, rings, cylinder prep, gaskets at least...and well your there so all new radiator hoses
Old Aug 26, 2020 | 06:12 PM
1971allchaos's Avatar
I have looked at the photos , multiple times .. And have to agree on a engine case as A last possible. Yet being that the engine case is a Molded cast of a Metal /aluminum..
Question1 -Do you have all the pieces?
Question2 - Can you braze weld?
Braze welding would be the cheapest process to attempt in fix the issue.
TIG welding the pieces would be the next process.. Professional would be advised
Old Sep 3, 2020 | 12:42 PM
Smokeys81's Avatar
I’m going to try and braze it this weekend. I’ll up date with results. Wish me luck.
Old Sep 10, 2020 | 04:10 PM
ACE VenTRa's Avatar
Any luck?
T-roy
Oct 22, 2017 07:40 AM
NewGuy
May 12, 2014 11:32 AM
BigJMerc
May 4, 2011 12:14 PM
dannyz
Jul 19, 2010 07:21 AM
macworld
Mar 27, 2006 09:54 AM
