could this be done with bafflectomy pipes
Old Oct 6, 2008 | 05:46 PM
Rocky-Top-Rider's Avatar
Rocky-Top-Rider is on a distinguished road
i have completed the bafflectomy and feel like i have lost quite a bit of mid range. found this and was wondering if it would be possible to implement it to sh bafflectomized pipes.
any input would be appreciated.
http://www.nightrider.com/biketech/exhaust.htm
Old Oct 6, 2008 | 06:16 PM
filter69's Avatar
Thats Mr Dill hole to you
This is what i tuned in on
If you where to shim your Needles on your bike you would get back your mid range a **** load of bottom end and maybe even a better tourqe curve up to top end...
By properly re-jetting the carburetor and adding a free flowing air cleaner to an engine with drag pipes, the maximum horsepower produced will improve over the stock engine. But there is a difference between usable power and maximum horsepower. The maximum horsepower of two engines may be similar, but the horsepower torque curves may be different. The area under the horsepower and torque curves defines the "power" the engine produces. The more area that is under the curve, the better the power.
And it only costs around 50 Cents to do it ....
Old Oct 6, 2008 | 06:26 PM
i ain't that mechanically inclined. is shimming needles difficult?
Old Oct 6, 2008 | 06:44 PM
filter69's Avatar
If you can get your tank off and the air box off you can prolly do it you dont even have to
pull the carbs or nothing... just pull the "black roundy things" off the top to remove the carb slide and take the needle out of the carb slide and drop a .030 to .060 washer on to the needle to raise your needles a bit to make the main fuel circuit come on faster of all the mods i did to my bike this was the best one hands down. thats a "quick" run down of the proc. if you serch around im sure you can find a good write up on it here on the forums
Old Oct 6, 2008 | 08:19 PM
filter, your shaved cat still doesn't look happy to me.
Old Oct 7, 2008 | 07:21 AM
RickB's Avatar
LOL No it doesn't look happy!
Back to topic, a #4 brass washer works well for shimming needles - the ones I picked up at the hardware store were .024 and are working well with my K&N (stock pipes still) so you may need to go with 2 washers or a thicker one to get you in the .040 to .060 range.
Old Oct 8, 2008 | 09:33 PM
filter69's Avatar
This is what he looked like B4 the "Tude" Adjustment. Just so you understand it had to be done for the safety of the western world as we know it.
Old Oct 12, 2008 | 05:55 PM
here is what i did with the sh. i really didn't notice any more response in the mid range.
Old Oct 12, 2008 | 05:58 PM
one of both pipes.
Old Oct 13, 2008 | 09:25 AM
malott442's Avatar
malott442 is on a distinguished road
If you angle those just right it will whistle.........
Old Oct 13, 2008 | 09:58 AM
Little_Horse's Avatar
2nd mouse gets the cheese
I would up the sizing on the washer seeing as drag pipes like the article is talking about tend to be a narrow diameter, making the washer in those take up nearly the entire inside diameter of the pipe. This idea basically is supposed to make you have some adjustment in you back pressure. With all the space around the bolt I don't think it is doing anything to restrick or build up pressure. Just my 2c
Old Oct 13, 2008 | 10:55 AM
armyguy8381's Avatar
armyguy8381 is on a distinguished road
I'm thinking SPark plugs Coils and Fire!!!!!!! Pretty cool looking a flame throwing SH
Old Oct 13, 2008 | 11:49 AM
Yeah... and I'd say it would probably be better to put a couple of smaller washers in the carbs and adjusting them for the open pipes... A small adjustment there will make a whole lot more difference than those...
Old Oct 13, 2008 | 11:53 AM
Heh... just put the PAIR crap back in there and you don't need spark plugs... I ripped mine out after scaring the crap out of my riding buddies... I was running a bit rich and the PAIR made flames the size of my hand at hard decel at lights... Cool, but totaly useless...
Old Oct 13, 2008 | 12:56 PM
prolly useless on the superhawk. i am gonna take out the baffles on my harley davidson and put these in there. they look a lot like big city thunder baffles, except only cost me about $14. i would like to adjust the washers in the carbs, but i am too scared i'd skrew it up.
Old Oct 13, 2008 | 01:33 PM
I used to do Key bangers.. Can shoot a flame out about 6 inches.. Again useless but lots of fun. Scare the crap out of who ever is around. Sounds like a 12 gauge going off. LMAO
Old Oct 13, 2008 | 01:54 PM
Worst case scenario... it doesn't improve anything and you but it back the way it was... It's less complicated than you think...
Old Oct 13, 2008 | 06:12 PM
yea i might get the guts to do the washers over the winter, but i know my abilities with small things. not good usually. i'd say you get some down time over there in sweden for the winter.
Old Oct 14, 2008 | 02:45 AM
Don't remind me please...
HU112BU
May 21, 2015 05:37 PM
Fox
Feb 7, 2011 02:28 PM
SuperhawkWolf
Mar 29, 2007 10:44 PM
Randman
Feb 6, 2007 08:16 PM
CNI Dawg
Nov 3, 2005 09:12 PM
