Coolant leak, ride aborted....argggggg
Old Feb 14, 2011 | 04:25 AM
Went to ride the bike yesterday and found a coolant leak at the back of the rear head. Cleaned it off, ran till warm,, and coolant in the same place, parting line at the gasket between head and cylinder..// Still possible it is leaking from farther up and forward and running back along the gasket line..... but I don't have that kind of luck....
Bike gets stripped tonight,, see if I can find the source with 15psi on the system.... might even do some UV leak test dye.....
Old Feb 14, 2011 | 05:52 AM
98VTRrider's Avatar
Man sorry to hear...on my first ride of the year saturday, about halfway through our ride we were going through some traffic lights, and a friend notice I was leaking coolant off my left side, coming from the lower left radiator hose end, but only leaked a few ounces we saw and then stopped.....guess it's that time of year...
Old Feb 14, 2011 | 07:44 AM
nekkid's Avatar
Let's make it 3 for 3...I just found and hopefully repaired a coolant leak too. Right at the lower hose as it attaches to the right side radiator.
I gave the system a vinegar/water douche, re-filled the system, and retightened the hose with a new, and slightly wider, hose clamp. Didn't see any damage to the hose or any cracks in the system.
Strange to have a leak develop where there was none before with no visible damage anywhere.
Old Feb 15, 2011 | 05:28 AM
Leak confirmed, Head gasket,...bummer... will order parts tis morning. Man, great weather is here this week, I deploy soon and will off the bike for another year... CRAP..
OK, self pity moment over....
I understand the rear head will come off the engine in frame, the question to those that have done it... was a huge pain to move in around the frame? Better off to remove the engine and put it on the bench?
Old Feb 15, 2011 | 09:28 AM
It's no problem removing the heads while the motor is still in the frame.
Old Feb 15, 2011 | 09:42 AM
Thanks for the confirmation.... so tonight it's off with its head.... Wish I could get a head gasket faster than 10 or so working days
Old Feb 15, 2011 | 09:59 AM
No worries.... just remember the 2 small bolts in the cam chain tower.....
It does suck to have to wait that long for parts though..... been there too many times.
Old Feb 16, 2011 | 12:25 AM
nekkid's Avatar
Stupid has a new name...
Not to hijack your thread but this is a story with a warning.
After I did all the work I noted in my earlier response to this thread, I took the Hawk out for a long ride yesterday. Out on the freeway it ran cooler than normal. I thought this was due to the flush job I did...I was happy. Back on city streets in stop and go traffic I noticed the temp rising; faster and higher than before in similar situations. Oh no, I guess I failed to fix the leak...except at stop lights, no coolant hit the pavement. Checking further I noticed no sound from the radiator fan.
I barely made it home before the temp gauge ('98) hit the red zone. Still no coolant spill or boiling sounds. After the bike cooled down I removed the fairing and uncorked the radiator cap. Still lots of coolant and no signs (or smell) of leakage. I pulled the temp switch wire and grounded it to the frame and the fan failed to spin. When I tried to spin the fan by hand I found it was binding on something. The coolant over flow tube was jammed between the rim of the fan and a frame member. I freed the tube and tried to ground the wire again; no go...I must have burnt out the fan motor. Last hope; check the fuse. It was blown and I replaced it with the spare that Honda knew I would need one day. Fan spins like a champ now.
Thinking back now, I remember a week ago I absent-mindedly tucked the loose looking hose back into the frame area while sitting a a stop light.
Old Feb 16, 2011 | 12:43 AM
saige's Avatar
the boss
can you do me a favor,when you take the head off,can you weigh it with the valve cover on it.i might make a deal for some heads but dont know the weight for a quote on delivery.
Old Feb 16, 2011 | 04:13 AM
You bet
Old Feb 16, 2011 | 06:02 AM
Are these VTR1000F head gaskets?
The question becomes,, anyone want to take a guess if what is in the picture are really VTR gaskets?
Pretty sure they are.. but like many of us who have spares from many different bikes, current, past, etc on the shelfs. Sometimes things get mixed up.
I'll have the head off tonight but wanted to see what you all had to say..
Thanks.
Attached Thumbnails Coolant leak, ride aborted....argggggg-sh-head-gaskets.jpg
Old Feb 16, 2011 | 06:30 AM
FL02SupaHawk996's Avatar
Fastest Color
Can't tell for sure from the pic but they look right:https://www.superhawkforum.com/forum...ad.php?t=17262
Old Feb 16, 2011 | 06:55 AM
Looks like they should be the correct item, but it's hard to tell for sure... Keeping my fingers crossed...
Old Feb 16, 2011 | 07:00 AM
Me too, should be here tonight or tomorrow, head will be off tonight.. With luck, and weather holds.... I'll be riding by Sunday ( Racing Sat, or we would be out then as well)
Old Feb 16, 2011 | 09:11 AM
Like the others have said, they do "look" like the correct gaskets.
Old Feb 21, 2011 | 06:58 PM
Life happens
Thanks to Cilby for sending me the head gaskets. (still have not received the ones I ordered )
Life happened..... so have been putting off the tear down till today. On the bright side, a Marquez Racing Bike took 3rd at Arena Cross in Belton Texas this weekend (my son ) And 900 feet of fence posts were driven into the ground
60 minuets in to it..
And it is apart.. and confirmed, head gasket leak.
You can clearly see the area the gasket was leaking at, and it exactly matches where I was seeing coolant on the outside rear of the head.
And you can see the very common "clean" spot on the piston, typical of a steam cleaned piston when you have a coolant leak.
Head is back on... cams in, timed, but done for the night.. 2 hours start to quiting point...... I'll come home at lunch and finish it up..
Attached Thumbnails Coolant leak, ride aborted....argggggg-apart.jpg   Coolant leak, ride aborted....argggggg-clean-spot.jpg   Coolant leak, ride aborted....argggggg-gasket.jpg
mkimber
Jan 13, 2008 06:18 PM
j_frank
Apr 28, 2007 11:40 PM
EngineNoO9
Oct 20, 2006 09:01 PM
EngineNoO9
Dec 21, 2005 06:10 AM
faz
Jul 29, 2004 10:58 AM
