Cheap Honda brand Oil FIlters, Oil, & drain plug washers
Old May 7, 2006 | 03:10 PM
CNI Dawg's Avatar
Posted this on another topic but it deserves it's own
Cheap honda oil filters, honda oil, drain plug washers, & other stuff....
http://www.hondadirectlineusa.com
Altho it's a cruiser web site you will find your Honda oil filter is the same. Only $6.99 - check the part number !!!
Same deal with the washers - check the part number !!!
See the micro fiche at Ron Ayers to cross check part numbers
http://www.ronayers.com/fiche/getdesc.cfm?man=ho]
filter - 15410-MCJ-003 $6.99 each
http://www.hondadirectlineusa.com/st...10&ID=68467410
oil plug washer - 94109-12000 12mm (package of 10) $5.40 (these are cheaper at Ron Ayers but not when you figure extra shipping costs)
http://www.hondadirectlineusa.com/vt...45&ID=68467410
Honda oil by the case
Free shipping
$5.00 handling fee if order less than $100.
No handling fee if order over $100
Old May 7, 2006 | 05:22 PM
jschmidt's Avatar
jschmidt
Of course, the best deal on washers is the one that's already on there. I replace these about once every ten oil changes.
Old May 7, 2006 | 05:45 PM
CNI Dawg's Avatar
Ever get any seepage reusing the old washer that many times?
Old May 7, 2006 | 06:51 PM
bluevtr's Avatar
bluevtr
I've reused the one on my goldwing since new. Never any problems. I couldn't see the logic in replacing each oil change unless it's damaged in some way. I just give a quick visual inspection, and back on it goes. (Prob. 8 times now)
Old May 7, 2006 | 07:17 PM
superhawk22's Avatar
Don't forget about this thread with cross ref #'s I've been using the wal-mart super tech st-7317 for $2.30 and so far no complaints.
https://www.superhawkforum.com/viewtopic.php?t=1987
Old May 7, 2006 | 07:33 PM
jschmidt's Avatar
jschmidt
Nope. But if I did, I'd certainly replace it.
Old May 7, 2006 | 09:22 PM
Randman's Avatar
Moderate-whore
That filter also fit my wifes ninja....I think it will also fit several other bikes as well....and no problems from either bike....
Old May 8, 2006 | 04:22 AM
shayne's Avatar
Re: Cheap Honda brand Oil FIlters, Oil, & drain plug was
I re-use washers as well. Annealing is the answer here. Heat it up and it becomes soft and will work like a new one.
I will also smooth mine over with a file too if it needs it, to ensure it is flat.
Old May 8, 2006 | 06:14 AM
Pdaddy's Avatar
Pdaddy
Thanks for the P/N on the wally world filter. That rocks !! Im almost to 500 miles on mine and Im changing the oil once I hit it. Im a freak about oil changing so this will make it cheaper/easier for me. Ill probably change every 1500 miles or so..
Old May 17, 2006 | 08:48 AM
RymerC's Avatar
RymerC
Just FYI- at work we change the crush washer on ALL hondas (cars) EVERY TIME we pull the drain plug. Given that alot of idiots overtorque them, and after that they're used up.
Old Jan 21, 2008 | 01:21 AM
viperkillertt's Avatar
Josh
viperkillertt
I have spent hours and days studying the damn HONDA oils and filters. I keep getting different numbers for the stock Superhawk oil filter number. Anyone have it? I am looking for the least expensive place to buy an oil filter online. I have found the MM9 on only a few websites. How many motorcycle filters does Honda offer?
Old Jan 21, 2008 | 10:11 AM
FL02SupaHawk996's Avatar
Fastest Color
OICDN did all the work for you last December:
Oil Filter Cross referencing...
For people who are curious, I searched and couldn't find anything....here's a list of cross referenced oil filters we can use on our Hawk.
I will never again, goto a dealer to buy a filter and dino oil (non-syn) for $25 ever again.....Well, atleast they helped me get a part number so I can cross reference stuff.....a buddy helped me find this info:
These Oil Filters
have 20 x 1.5mm threads,
14 psi by-pass valve,
anti-drain back valve,
2.3" O.D. gasket
2.5" to 3.5" long.
If you have the room, I recommend the longer filters.
Motorcycle Filters.
None are recommended.
* AC Delco PF2135
* AMSOil SMF103
* Carquest 85358
* FRAM PH6017A
* Honda 15410-MCJ-000
* K&N KN-204, about $13. Metric nut on end for easy removal.
* NAPA Gold 1358
* Purolator ML16817. Imported, not made by Purolator.
* STP SMO 17
* WIX 51358
Recommended filters.
All have superior
filtering.
About 2.5 inches long.
* Purolator Pure One PL14612, about $6.
* Mobil M1-108, about $12.
Made by Champion.
* Bosch 3300, about $6.
Made by Champion.
About 3.25 inches long.
* Purolator Pure One PL14610, about $6.
* Mobil 1 M1-110, about $10.
Made by Champion.
* Bosch 3323, about $6.
Made By Champion.
* WalMart SuperTech ST7317,
about $2. Made by Champion.
Automobile Filters, about 2.5 inches long.
* AC Delco PF1237
* Baldwin B1400
* Firestone TF2876
* Hastings LF113
* NAPA Gold 1365
* Purolator L14612
* STP S-02876
* WalMart SuperTech ST6607
* WIX 51365
Automobile Filters,
about 3.25 inches long.
* AC Delco PF-2057
* Auto Pro 2356
* Autopride CF240AP
* Baldwin B1402
* Carquest 85356
* Carquest Red B4620
* Casite CF240
* Castrol 7317
* Champion Labs Ph2867
* Defense Filters Dl7317
* Deutsch D-370
* Federated Filters LF240F
* Fram Double Guard DG7317
* Fram PH7317
* Fram Tough Guard TG7317
* Fram Xtra Guard XG7317
* Group 7 V4610
* Group 7 V4620
* Hastings LF240
* Mighty M4612
* Motorcraft Long Life FL-821
* Napa FIL1356
* Napa Gold 1356
* Parts Plus PH2867
* Pennzoil PZ-109
* Penske 7317
* Powerflo SL14610
* Powerflo SL14620
* Pro Gauge PGO-4620
* Pro Tec 164
* Promotive PH4610
* Pronto PO3593A
* Purolator L14610
* Service Champ OF-4622
* Shell SH48
* Shell SH529
* Stp S-02867.
* Valvoline VO50
* Warner PH2867
* Wix 51356
Viper, You might try the search tool sometime
Hope this helps...now you can just goto Autzone or whatever and snag up some filters...might help out the SHawk noobs (such as myself)
oicdn is offline Add to oicdn's Reputation Report Post Reply With Quote
Old Jan 21, 2008 | 10:22 AM
Josh
viperkillertt
Are you replying to me. I was asking a very simple question. What is the stock one. I obviously read and reread this millions of times. THis is clearly not a simple question to answer. I have spent months trying to figure out exactly which one is the very best for my beast. I wont you anything from wally world, so i am still trying to figure it out. I just wanted to know what the stock number was. Please don't ever say i don't search. I went through every post that had "oil filter" in it last night and many other times trying to answer my question.
Old Jan 21, 2008 | 10:23 AM
Fastest Color
This is a good reference site for filters too:
http://motorcycleinfo.calsci.com/FilterXRef.html
Old Jan 21, 2008 | 10:27 AM
Josh
viperkillertt
Yeah, i have read that throughly. It is really good. Anyone know what the exactly honda stock model number is? The number i have is the MM9, but it seems that it is a rarer number and other numbers are used often, but they look like they are the exact same size. So i am just trying to track down the stock model and if they have changed the model number to a more modern model number? I haven't been able to find the modern MM9.
Old Jan 21, 2008 | 10:29 AM
Fastest Color
Sorry bro...maybe this will help
Part Number: 51358
UPC Number: 765809513587
Principal Application: Honda Motorcycles + Industrial Engines, I-R, Komatsu, Kubota, Kia (95-05), Mercury, Arctic Cat, Polaris, Subaru (06), Yamaha, Other
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.782
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=13/52
Burst Pressure-PSI: 265
Max Flow Rate: 8-10 GPM
Nominal Micron Rating: 14
Old Jan 21, 2008 | 10:32 AM
Josh
viperkillertt
Part Number: 51358
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.782
No worries, so that is the stock one. Very interesting. Thanks!
Fastest Color
That's not the Honda# either 51358 is the Wix Filter number...I'll keep looking!
Old Jan 21, 2008 | 10:38 AM
Fastest Color
Try this bro:
up to 2002
Quality Parts Unlimited OEM replacement oil filters. OEM # 15410-MM9-013 / 16097-1061 / 16097-1063 / 3FV-13440-00.
after 2002
Breakthrough technology allows filter to trap particles down to 10 microns in size, conventional filters only trap particles no smaller than 20 microns.. Synthetic filter material allows motorcycle engines to last longer. OEM # 15410-MM9-013 / 16097-1061 / 16097-1063 / 3FV-13440-00.
http://www.gdlcycles.com/asp1/findme...00&cat=filters
Old Jan 21, 2008 | 11:10 AM
Thumper's Avatar
Nope,
always torque to Manf. Spec. my 26 year old CBF (one owner) still has the original washer as well.
If they leak i say replace them, but if they are true and not de-formed i see no need ot replace.
Old Jan 21, 2008 | 11:28 AM
ghopki1's Avatar
Originally Posted by Thumper
Nope,
I change oil in my off-road bike almost every ride. Still on the factory washer. If it was leaking any, I would see dusty buildup around it. So far so good in 4 yrs.
Old Jan 23, 2008 | 04:11 PM
They DO deform. That just means they're sealing properly!
Old Jan 23, 2008 | 06:32 PM
RK1's Avatar
RK1
I've got 7 oil changes on my VTR's original washer and it's still working like a champ. I've been riding since the 70s and don't remember ever replacing one.
Old Jan 23, 2008 | 06:52 PM
Holy crap! Now we're down to oil washers???
I see all the heavies weighed in on this one. I guess that means everybody is having a very boring winter.
It has been no peach orchard here.
Some guys are riding here but it was 36F and misting all day. Nobody is having fun. These guys bought high and got caught by the cost of gas.
They gotta ride it. It's just too expensive to drive the truck.
Old Jan 23, 2008 | 07:14 PM
RK1's Avatar
RK1
Well at least nobody's started another "what's the best VTR engine oil" thread.
Besides, I'd rather talk about drain bolt washers all day long than watch 5 minutes of TV about Britney Spears or the dead Broke Back Mountain guy.
Old Jan 24, 2008 | 08:59 PM
Yeah, no ****! The sordid **** coming out of Hollywood is second only to the scarey **** happening on Wall Street.
thedeatons
Oct 5, 2013 01:50 PM
DutchStorm
Jun 7, 2013 08:21 PM
NWbrew
Apr 19, 2009 10:23 AM
Syclone
Oct 6, 2007 10:21 PM
mikecronis
Jun 10, 2005 12:59 PM
