chain
Old Apr 13, 2009 | 04:19 PM
SILVREVO8's Avatar
SILVREVO8 is on a distinguished road
chain
ok guy were is a good place 2 buy a chain? should i stick with a stock or get after market one. and who has the best prices?
Old Apr 13, 2009 | 04:51 PM
loserbaby's Avatar
jet wrench
loserbaby is on a distinguished road
I bought a stock size 530 chain 120 links for about $100, I replaced it due to masterlink failure, otherwise I surely would have bought sprockets also and possibly went with a 520 chain. You'll have to read around and see what works for you. tThere are pros and cons to going to a 520 chain, I think the cons are higher, but the chain and sprocket set can be obtained relatively cheap on eBay.
LB
Old Apr 14, 2009 | 01:31 AM
Circuit_Burner's Avatar
guru of things sparky
Get a Regina.
They last the longest ive found.
Better chain.
http://www.reginachain.it/eng/index.asp
Old Apr 15, 2009 | 02:28 PM
k-d-williams's Avatar
I replaced my 530 chain with a DID 520 O-Ring chain back in October '08 with a 15 tooth front and 43 tooth rear sprockets. I have already (6 months) stretched the chain to "no more adjustments to be made point" and is wore out. I do alot of wheelies and take off like I'm heading to a fire everytime I take off. So if you are hard on the throttle, I would go back with a good 530 chain. Just my 2 cents.
Edit: Chain lasted 4600 miles and yes it was lubed every week. The 530 lasted 15000 miles with the same abuse.
Old Apr 15, 2009 | 03:55 PM
SILVREVO8's Avatar
well my chain has 20,000 miles on it and i dont think it was ever ridden that hard. when i was washing it i noticed that it was in the replace part and i just dont want it to break on me
Old Apr 15, 2009 | 04:27 PM
reaper's Avatar
Look at the D.I.D chains, they are quite beefy.
amhsraptor
Jun 12, 2010 08:10 AM
duran
Aug 27, 2007 07:57 AM
itsjason13
May 2, 2007 09:31 PM
willie
May 1, 2007 01:52 PM
bkelsey
Apr 25, 2007 06:24 AM
