Anyone ever use DOT2 instead of DOT3 brake fluid?
Old Apr 24, 2007 | 01:05 PM
seattlesucks's Avatar
seattlesucks
Any problems or issues caused by it?
Old Apr 24, 2007 | 01:47 PM
www.shotimes.com/SHO3brakefluid.html
http://en.wikipedia.org/wiki/Brake_fluid
Don't.
DOT 2 is essentially castor oil; DOT 3, DOT 4, and DOT 5.1 are composed of various mineral oils, glycol esters and ethers; some are synthetic oil based, and DOT 5 is silicone-based.
Old Apr 24, 2007 | 02:10 PM
seattlesucks
Wait... I may be confused. Which is the one recommended for superhawks? One number lower than that...
Old Apr 24, 2007 | 02:34 PM
superbling's Avatar
It's on the brake reservoir cap.
Old Apr 24, 2007 | 02:44 PM
seattlesucks
yeah... I don't have a superhawk anymore. The reason I ask, I was using a different brake fluid than the suggested, and I crashed while braking hard. I was wondering if it was possible that the fluid boiled and locked my brakes... was prolly just my fault though.
Old Apr 24, 2007 | 03:05 PM
You can usually use higher number fluid instead of the lower number, but want to avoid reversing that. I think it calls for DOT4 so you might have had DOT 3 in there, slightly lower boiling point, but bad brake fluid with water in it is more likely to cause problems than the 45 degree difference when both are over 400 F boiling point.
Old Apr 24, 2007 | 07:01 PM
Boiling will cause the lever to get soft/move to the grip. That's what you call brake fade. Hate to say it but it was probably you. Maybe tires or something on the road though, too.
Old Apr 25, 2007 | 09:43 AM
SuperLoud's Avatar
SuperLoud
One possibility
I've heard that if you brake hard on a superhawk and you weigh over 150 lbs the front forks can bottom out and cause you to lose control.
can anyone else confirm this?
Old Apr 25, 2007 | 10:04 AM
dantropolis's Avatar
dantropolis is on a distinguished road
I believe 3 and 4 are compatible, some bottles are even labeled DOT 3, 4. Do not mix 5 with anything else. I've been told that switching to 5 requires that you fully drain and flush the entire system.
I'm betting you had 3 in there instead of 4, in my experience it's pretty tough to find 2.
And it's gravity and momentum that caused your crash.
Old Apr 25, 2007 | 10:45 AM
Mick-e's Avatar
Mick-e is on a distinguished road
Originally Posted by SuperLoud
One possibility
Yes braking hard can bottom out the forks transferring more energy to the front tire, and thereby losing traction. How much you weigh does effect that, but there is not defined number.
DOT2?
Where on earth would you even find that? I don't even know where to buy DOT3. I use DOT4 on all my street bikes, and DOT5.1 on my race bike.
Old May 6, 2007 | 01:27 AM
seattlesucks
One possibility
I can confirm it. That's exactly what happened. The forks bottomed out, and next thing I knew there was no more bike. ground sky ground sky ground sky ground sky ground sky groud sky sliiiiiiiiiiiiiiiiiiiiiiiiide..... repeat....
Letsrideinsc
Dec 15, 2010 06:21 AM
justinity
Sep 19, 2010 04:05 PM
Scoutpilot
Jan 16, 2009 05:05 PM
HawkRider98
Sep 10, 2008 09:07 AM
AKohler996
Aug 3, 2007 07:47 AM
