Accelerate in first without wheelying?
Old May 16, 2013 | 09:40 PM
Chrisguilday's Avatar
Chrisguilday is on a distinguished road
For the life of me I can't go fast in first gear or my front wheel will come up. Doesn't matter what I do.
Any RPM below 8 grand and my front wheel comes up. I even tried practically sitting on top of the gas tank. Still almost flipped.
I've tried gradually rolling it on, but I can't twist the throttle past 75% without it wheelying.
Any suggestions? Could it be suspension? Or is it just not possible to go fast in first? I usually just skip it and go into second.
Old May 16, 2013 | 11:45 PM
Check the gearing... If it's the stock 16/41, it's possible with a little finesse, but takes practice... If it's not stock, it's just about impossible...
Old May 16, 2013 | 11:51 PM
Back sprocket is stock. I'm assuming front is too but I'll have to check later.
Old May 17, 2013 | 01:47 AM
Tebs's Avatar
Tebs is on a distinguished road
I just changed to a 16/43 setup and I have no problems keeping the wheel down...
Old May 17, 2013 | 03:51 AM
Well... I can't tell you how your bike is running or not... But for me, whacking the throttle open in first would probably result in the bike making a complete sommersault...
Infact, getting my bike to full throttle in second or third without standing it up, takes a bit of finesse...
While I'm running stock gearing, there is nothing stock about my engine... I'm actually contemplating going to longer than stock gearing...
Old May 17, 2013 | 07:29 AM
sailorjerry's Avatar
i can tell you that if you can hit anything past 40 to 50% throttle in frist and keep the front wheel on the ground then there is something wrong with your bike, i too just changed to 16/43 and i pull the wheel out of every first gear corner.
As for the issue of stock gearing and keeping it down, it is very possible unless you are pinning it between 2500 to 5k, in which case its most likely going to come up, BUT thats the fun of the hawk right?
Old May 17, 2013 | 08:07 AM
Which is why it's odd that some people run 15/43 or even 15/44 to me... but to each their own!
Old May 17, 2013 | 08:23 AM
RCVTR's Avatar
That's why I went to 15/42 gearing. First gear is to get off of stop. Shorter gearing lets you use 2nd off slow corners. The transmission shifts better and you get the bike stood up as you are rolling into the fat part of the torque band, so it's easier to ride hard.
Old May 17, 2013 | 08:32 AM
I'm used to it by now... So much infact that when I swapped bikes with a friend riding a spanking new CBR 1000RR, it felt odd not having the front go light every time I accelerated... (on that bike it's not hard to loft the front, but it has to be a conscious act...) On the flipside, his comment after riding my bike was that he was kind of scared of it, as he plain and simple could accelerate without the front coming up...
Old May 17, 2013 | 10:09 AM
Codeblue's Avatar
Codeblue is on a distinguished road
The bike has a certain torque at the rear wheel when the front wheel will come up. It doesnt matter what your gearing is, the minimum time accelerating from 0 to 40mph (or whatever) without wheelieing is still going to be the same...
Or are you purely wanting to be able to thrash first gear without wheelieing, and dont care about your speed of acceleration?
If that is the case, go get a 17T front sprocket and a 38T rear or whatever.
Old May 17, 2013 | 10:56 AM
No I was just curious if there was a method to pin first gear to get full acceleration without wheelying. Right now I always have to let off when the front wheel comes up.
Old May 17, 2013 | 11:06 AM
Shimming the rear had a noticeable side effect of making the front end harder to pick up for me.
Old May 17, 2013 | 11:14 AM
Pull the front plug wire.....
Old May 17, 2013 | 11:29 AM
lol!
Old May 17, 2013 | 02:47 PM
That would make it a VTR500f right?
I say dont worry so much about fixing it but learn how to control and enjoy it. Like i said earlier thats one of the many things makes me love the hawk over I4's.
Old May 17, 2013 | 02:48 PM
zxbud's Avatar
Yah, ya can. Just consider the cops are watching and a wheelie can be a 'go to jail, wreckless driving offence'. I been stopped twice in the last few months. First time I was mistaken for a runner. When I took my helmet off and with his hand on his gun officer said "well, you ain't the one". Then we both laughed and had a good talk. Second time I was at fault for expired tag (8 months expired). So, they're always watching and you will get caught.
Old May 18, 2013 | 01:17 PM
brothermike's Avatar
brothermike is on a distinguished road
Put on a hundred pounds, mine only slightly comes up and is good fun.
Old May 18, 2013 | 01:24 PM
lloydievtr's Avatar
road racer v2 power
i cant give it more than 1/4 throttle in first without looking at the sky ,,, tis fun
Old May 18, 2013 | 03:27 PM
I'm running stock gearing and I can't lift the front with just power alone in first. No way in second unless I bang the clutch. I assumed it was the elevation (4200 ft and above) that I ride at, but maybe my bike is down on power. It pulls very smooth with no flat spots (that I can feel). I am a squid so that could be a possible reason.
Old May 19, 2013 | 04:22 AM
zxbud's Avatar
What can account for such a huge disparity between machines that develop about 65lb ft of torque? Truly shocking!
sweetriden76
Sep 22, 2009 05:20 PM
notquite
Aug 28, 2009 08:47 PM
vtrlvr
Feb 8, 2007 07:55 PM
dpenix76
Nov 2, 2006 04:03 AM
roadrun_fr
Aug 7, 2005 02:09 PM
