VFR fork length
Old Jul 7, 2014 | 07:41 AM
VFR fork length
I have a long way to go on my Gold Wing resto project so I need to pick away at it every day. Was trying to research shim stack info on SH stock forks and ended up an a VFR forum reading a thread on a fork/brake mod using SH stanchions grafted to VFR tubes. I think that the guy also used the damper rods from the SH, but that is something I'll work out later.
The question is: can someone with a 5th gen VFR measure from the center of the axle to top of fork length. I don't need perfect accuracy.
From the info on the thread VFR forks are longer than SH forks. The rough plan is to, when I finally finish the fork swap on the SH, is to use SH triples and forks on the GL. The stock GL front wheel is 19" and while the stock GL fork length seems to be the same as the SH, going to a 17" wheel will change the front geometry and ground clearance way too much. The thought is to swap in VFR tubes and use the SH stanchions. That will net much better brakes, better forks, and better tire choices. I realize that there will be some fooling with the steering stem, making sure the geometry is good, etc, but from the info I found on a GL site this is a doable swap.
Thanks in advance
Rock
Sep 16, 2008 04:11 PM
roisman
Mar 25, 2008 10:43 AM
cliby
Mar 8, 2007 06:13 AM
zimm
Sep 5, 2006 08:56 AM
Radiaoktiv
Aug 29, 2006 07:42 AM
