Moriwaki cams
Old Apr 17, 2011 | 04:12 AM
mrmhrm9598's Avatar
mrmhrm9598 is on a distinguished road
Moriwaki cams
Anyone know where I can get a set of Moriwaki cams?
Old Apr 17, 2011 | 11:21 AM
cliby's Avatar
they come up on ebay from time to time (cams). my own experience is that without other mods, by themselves they don't do much. You can probably accomplish most of the same by timing the cams to a different spec to match or swapping in/ex cams. with other mods to intake/exhaust/pistons they add some.
Old Apr 17, 2011 | 11:35 AM
mrmhrm9598's Avatar
The only mods that I currently have are Two Brother's exhaust,jetted and K&N filter. What would you recommend before I started looking at cams?
Old Apr 17, 2011 | 11:43 AM
nykuryu's Avatar
nykuryu is on a distinguished road
maybe high comp/over sized pistons?
Old Apr 17, 2011 | 11:47 AM
mrmhrm9598's Avatar
I ride as much as possible. I may start looking at a motor to build if I can find a good rebuildable one to start with.
Old Apr 17, 2011 | 11:50 AM
you can always try Revolution Racing in the UK (but they're not cheap.....)
Old Apr 17, 2011 | 11:58 AM
mrmhrm9598's Avatar
I will check with them. I just emailed a guy about an engine with a bad top end. Hopefully I can get it and start the build.
Old Apr 17, 2011 | 05:24 PM
JamieDaugherty's Avatar
Have you thought about getting your stock cams reground? That's normally cheaper and you can get a grind that matches the rest of your setup. I've found that to be the best way to go for most people.
Old Apr 17, 2011 | 08:33 PM
lukenukem47's Avatar
Reground?
Who can do that? I have a lower with high compression pistons and an upper thats ready to be rebuild.
Old Apr 17, 2011 | 09:03 PM
Web Cam Inc. - Performance and Racing Camshafts
Megacycle Cams
Old Apr 17, 2011 | 09:07 PM
nykuryu's Avatar
Are you in cali? Just had someone email me about parts for his track bike
Old Apr 18, 2011 | 06:12 AM
mrmhrm9598's Avatar
I am in Va. Not many Hawk riders in this area. Most do not even have a clue what my bike is. I have had a lot of guys pull up on me thinking it was a 500 ninja. they figured out it wasn't pretty quick. I will definitely check on getting them reground. thanks for the info.
Old Apr 18, 2011 | 10:16 AM
Don't forget Colt Cams and my personal favorite Shadolt Cams in Canada.
Old Apr 19, 2011 | 04:50 AM
Stumpy's Avatar
I have an extra set of stock cams you can have cheep if you need some to send in for the work.
Old Apr 19, 2011 | 05:48 AM
FL02SupaHawk996's Avatar
Fastest Color
Moriwaki Candy
PM sent
zmaniv
Aug 10, 2011 12:41 PM
RCVTR
Jun 8, 2011 08:11 AM
stefano
Aug 5, 2007 09:26 PM
Mick-e
Feb 27, 2007 05:20 PM
miken996
Jan 12, 2006 05:53 PM
