F/S Carb Tools
Old Apr 19, 2013 | 01:31 PM
RWhisen's Avatar
Former Superchicken Owner
F/S Carb Tools
Like messing with your carbs? These tools make it so much easier!
Each are 80 USD shipped to your location in the lower 48.
CARB D SCREW ADJUSTMENT TOOL
SOLD TO 8451Hawk
Morgan CarbTune Pro make synching your carbs in 5 minutes possible.
Don't use some flaky tube and oil, use the right tool and get the right
results!
Old Apr 19, 2013 | 05:43 PM
RWhisen's Avatar
Carbuerator D Screw tool sold to 8451Hawk. Thanks Mike and happy wrenching.
Old Apr 19, 2013 | 05:47 PM
Thanks and the sync tool is nice and I would have got that also but I still have my old Hg filled sticks (don't tell the EPA )
GLWS
Old Apr 25, 2013 | 02:03 PM
The pilot tool showed up today.....
Still looks brand new.....
No more pulling carbs to adjust pilots for me......woot
Thanks again
Old Apr 25, 2013 | 03:16 PM
cybercarl's Avatar
I had a sneaky feeling you might have grabbed that adjuster. LOL
Old Apr 25, 2013 | 05:34 PM
RWhisen's Avatar
Thanks again
You're welcome Mike, it makes life so much easier. Notice it has an index mark on it that you set once you get it on the screw. It makes it easy to count the turns and keep track of them.
Old Apr 25, 2013 | 06:35 PM
twist's Avatar
I have to ask, where can that D screw tool be had if I were to want to buy one?
Old Apr 25, 2013 | 06:44 PM
RWhisen's Avatar
Here:
Honda - 07KMA-MN9A100 - PILOT SCREW WRENCH
and here:
HONDA-POWERSPORTS 07KMA-MN9A100 PILOT SCREW WRENCH
Old Apr 25, 2013 | 08:07 PM
reaper's Avatar
Or this little jewel which will save you some serious cash
Motion Pro 90 Degree Carb Tool With Bits 08-0229
I have one and it works great.
Old Apr 25, 2013 | 08:54 PM
Or build one for 1/10 the cost
Old Apr 26, 2013 | 07:37 AM
twist's Avatar
damn! so that's what the honda tool looks like. It doesn't look like it can be used while the bike is running without getting burned hands. The motion pro looks good but will it fit in there well enough to be practical? Making my own tool looks like the better bet if I can manage to create a flex bit of my own. Maybe pull the screws and just dremel a slot for screw driver and be done with it.
Old Apr 26, 2013 | 08:02 AM
Thats what i did, https://sdp-si.com/eStore/Direct.asp?GroupID=271
key component is the motion transfer.. Miter gears were cheap.. some rod, a replacement D bit from motion pro, and a small hunk of aluminum hex stock..
works great.
Jens_denmark
May 17, 2010 10:49 AM
captainchaos
Jun 4, 2007 12:39 PM
xecutech
Apr 15, 2007 07:05 PM
ClevelandSuperhawkRumble
Feb 20, 2007 11:19 PM
superbling
Dec 21, 2004 08:54 PM
