2001 Honda Superhawk VTR1000 Erion Red
Old May 23, 2016 | 08:25 PM
thedeatons's Avatar
It is with a heavy heart that I do this... But the show must go on...
Bike is in Caldwell, Idaho, just west of Boise. If you fly in to Boise I will pick you up at the airport and you can ride it home...
2001 Honda Superhawk VTR1000 Erion V Twin Red
This has been the best bike I have ever owned. Way more character than any other bike I have ridden. It wheelies everywhere (assuming you want to), but is also super comfortable. Wonderful to look at, I often find myself staring at it in the garage. . .
I got this bike from my father. He was 59 when I got it from him, and still riding it! Since I have owned it I have had nearly everything powdercoated black, and done ALL the reliability updates (installed manual cam chain tensioners, a MOSFET regulator/rectifier, and more).
Valve clearances were just checked a couple thousand miles ago, and set to stock spec with new shims (I did the work). New tires and battery just installed. Forks just rebuilt with heavier springs and in my opinion the best oil. Front end dampening now matches the rear, very balanced bike, setup for about a 160lb rider.
It's a bit cold blooded (48mm carbs, biggest carbs Honda ever put on a motorcycle), but once the coolant temperature reaches about 125 on the digital readout it is ready to go with no more choke.
Short gearing means lots of fun from stoplight to stoplight, and no vibrations in top gear on the freeway, just a nice riding bike. Super quick bike, I have no doubt it would post mid to high 10s in the quarter mile.
No test rides. . . If you are looking at this bike you know what it is, and by looking at the list of things I have done can probably tell how amazing the bike is. . . Whatever you are imagining is true, it is a fantastic bike.
This bike just won VTR of the Month on the Superhawk Forum (March 2016)
Erion racing exhaust
Nitro plated header (welds near exhaust port ground down to increase flow)
Modified "hawkrider" carb set up (with 45 pilots, stock mains, needles shimmed, and HRC slide setup-hole epoxied)
Stock air filter
Adjustable mixture screws
Lightened flywheel to Roger Ditchfield specs
Galfer stainless steel braided brake lines front and rear
Galfer rear wave rotor
Honda CBR900RR rear wheel
Honda CBR900RR swing arm brace welded on
Modified coolant overflow bottle location
Pair removed with block off plates installed
Push throttle cable removed
Yamaha FZ1 mirrors
Zero gravity tinted double bubble windscreen
Roger'd (Roger Ditchfield modded) front forks with YZF 600 fork springs and 7.5 weight Silkolene Pro RSF oil
MCCT cam chain tensioners (stainless hardware used)
Sargent seat with carbon look upholstery and red piping
HRC rear brake reservoir delete (Tygon 2375 tubing and HRC cap)
Nicky mod done to front sprocket cover
Lockhart Phillips stainless fender eliminator kit
Lots of polished stainless steel hex head bolts
Red powder coated valve covers
Red powder coated rear brake caliper
Lots of black powder coating throughout, including frame, subframe, swingarm, oil pan, clutch cover, flywheel cover, clip-ons, fork legs
Bedliner'd starter casing and chin fairing
Lockhart Phillips tinted front and rear turn signals
Polished rear brake pedal and shifter
Dialed in shifter linkage including aluminum shift shaft, Heim joints, and bronze shifter bushing
Woodcraft rear brake return spring for better feel
Extra heavy bar end weights and original handlebar weights installed with new rubber
All ***** tapered steering head bearings
Quick release gas tank fasteners
Redline 10 W 40 synthetic oil
Mobil 1 oil filter
90° aluminum valve stems
New Bridgestone Battlax BT023 rear tire (42psi)
New Bridgestone Battlax BT016 front tire (36psi)
New Interstate battery
Renthal ultralight steel front sprocket
JT steel rear sprocket 15T
EK gold 530 chain 42T
Kawasaki ZX-10 MOSFET regulator/rectifier installed - No more failures!
Matching 6 spoke CBR600F3 Front wheel will go with the sale
$4000 Cash Only...
Attached Thumbnails 2001 Honda Superhawk VTR1000 Erion Red-535.jpg   2001 Honda Superhawk VTR1000 Erion Red-534.jpg   2001 Honda Superhawk VTR1000 Erion Red-539.jpg   2001 Honda Superhawk VTR1000 Erion Red-536.jpg   2001 Honda Superhawk VTR1000 Erion Red-537.jpg
2001 Honda Superhawk VTR1000 Erion Red-538.jpg   2001 Honda Superhawk VTR1000 Erion Red-541.jpg   2001 Honda Superhawk VTR1000 Erion Red-542.jpg
Old May 23, 2016 | 08:30 PM
James!
Old May 23, 2016 | 10:22 PM
What!?
Even Steve is short on words!
Old May 23, 2016 | 10:42 PM
Aquasnake's Avatar
What the??????? This is a joke, right? James?
Old May 24, 2016 | 06:09 AM
thedeatons's Avatar
Nope. No joke.
Change of lifestyle for my wife and I.
James
Old May 24, 2016 | 06:50 AM
archaicguy's Avatar
Wow...... Best of luck to you
Old May 24, 2016 | 09:58 AM
ren's Avatar
ren
Hope all is well man, please stick around and post with us still despite not having that bike, would be sad to lose your experience AND presence
PS your craigslist post was flagged for removal
Old May 24, 2016 | 10:22 AM
JamieDaugherty's Avatar
Oh man that is a good looking bike.
Old May 24, 2016 | 11:25 AM
Hangfly's Avatar
Maybe we flagged James' CL post to prevent losing him on this forum.
It will be sad to see you go.
Old May 24, 2016 | 03:06 PM
thedeatons's Avatar
Lol... Thanks guys...
Not sure what is up with craigslist, just reposted it...
James
Old May 24, 2016 | 03:12 PM
Three minutes after you posted it, it is flagged for removal. You must have pissed someone off on Craigslist and they want to mess with you.
How much are you asking for the bike?
EDIT: Nevermind, I see you haven't edited your original posting with the new address.
Old May 24, 2016 | 06:34 PM
thedeatons's Avatar
Sorry, added price
Old May 24, 2016 | 07:32 PM
Nope. No joke.
James
Best of luck with the sell James. I think you are 100% good on price. We all know how much love was put into this hawk... where it came from etc. Stay firm my friend and,
By all means hang out with us once in a while. Let us know what ya get to replace the old bird. I am right with ya but, for now I just can't even think about letting her go, even though I've found a more comfortable, more modern steed. Thing is, it's been sooo damn reliable (ie faithful), how could I?
Old May 24, 2016 | 09:22 PM
Meier Link's Avatar
That one guy
Jump that price up another 4k and keep the lady happy that you are "trying to sell it."
I know I have bad jokes. Hate to see you part ways with it but I understand. Done it too many times with bikes I swore I would never get rid of yet I quit riding for almost 8 years before buying the hawk I have.
Best wishes for your future endeavors.
Old May 29, 2016 | 06:08 PM
thedeatons's Avatar
The end of an era...
Delivered the Superhawk to its happy new owner today. A good friend of mine from church who I ride with regularly... He and his father are collectors who have owned 150+ motorcycles. Quite honored to have them want the bike.
I'll stick around and hope the new owner "dave" will chime in soon.
James
Old May 29, 2016 | 06:30 PM
Well James, glad a trusted owner took the keys. That has to make it a little easier.
Old May 29, 2016 | 06:33 PM
thedeatons's Avatar
Yep. I'm sure i'll be able to ride it whenever i want. He would probably sell it back to me even...
He told me he plans to put new fairings on it
Guess it will keep getting better, which makes me happy.
James
P.S. I'll post a thread soon with all the hardware sizes i've found for the bike, and the best source for polished stainless fasteners.
Old May 29, 2016 | 09:26 PM
I guess.. best of luck James, you had a great input on this community and no doubt an amazing looking bike with superb level of details, down to every bolt!
Hope to still see you around bro'.
Old May 29, 2016 | 09:39 PM
thedeatons's Avatar
Aww... Thank you guys for all the kind words.
I'll still be around... In fact i want to help the new owner find a stock undertray to replace the cracked one... If anyone knows of one, please let me know
James
Old May 30, 2016 | 12:38 PM
Fastguy59's Avatar
I will miss your posts and insight!
Old Jun 9, 2016 | 07:27 PM
thedeatons's Avatar
Sold the Superhawk... I'm picking up this 1300 VStar on Monday...
Old Jun 9, 2016 | 07:28 PM
thedeatons's Avatar
Another pic...
James
Old Jun 9, 2016 | 07:49 PM
Looks comfy! But WOW, what a difference. I don't think I'll ever be ready to shift gears to that style bike. I had to test ride an 03 Roadstar Warrior after changing tires today. The forward foot position is sooo un-natural for me. Don't like it.
Pretty clean looking bike James. The Mrs. will be happy!
Old Jun 9, 2016 | 08:03 PM
thedeatons's Avatar
And that's exactly why I bought it... My wife and I have been riding together since we met. When she tells me she doesn't want to ride anymore because the bike isn't comfy for her, that is a major red flag for me.
I decided to give away some of myself, and try this. Better to be less selfish and have my wife ride with me is my reasoning...
Anyway... Motorcycles are like hair. If ya don't like it, change it
James
Old Jun 10, 2016 | 10:02 AM
nnjhawk02's Avatar
Good Luck
But Shame on U
U should have went for a Sport Tourer
Stay Safe
Old Jun 10, 2016 | 10:53 AM
thedeatons's Avatar
I considered that... But part of this transition is to limit my being reckless... The Superhawk was literally being wheelied through downtown, turned at obscene angles (both tires are worn to the outer edge)... The V-Star will help me be less illegal...
Another aspect to a Sport Tourer is the constant frustration that it doesn't turn as well as a pure sportbike, or doesn't wheelie as well, or isn't as light... etc... With the V-Star I have zero expectations of it being anything remotely resembling my Superhawk, or CBR900RR, or R6, or ZX-7R...
It's a comfy way for my wife and I to spend time together and enjoy the scenery.
James
Old Jun 10, 2016 | 12:52 PM
Be carefull turning that beast. I remember my first time on a big bike. It was my Dad's Harley Fat Boy. I have been used to smaller, more nimble bikes and I came into a turn a little fast for the Fat Boy. It wasn't very fast at all, but when I leaned that bike over, I was greeted with metal scraping and sparks. I learned pretty quick to take turns slowly with that behemoth.
Have fun riding with your wife!
thedeatons
Apr 13, 2018 12:03 AM
thedeatons
Nov 16, 2015 08:45 PM
ebbhead
Jan 13, 2013 11:11 AM
sscooter
Feb 27, 2012 06:50 AM
ebbhead
Nov 20, 2011 01:10 PM
