ARGH! The Grease!
Old 03-12-2017, 08:41 PM
KLR996's Avatar
KLR996 is on a distinguished road
ARGH! The Grease!
What do you use to clean the grease that accumulates on the rear wheel, chain guard, kick stand, etc? I've tried a couple kinds of degreaser and they barely touch it. I'm tired of it. There has to be another (better) way.
KLR996 is offline
Old 03-12-2017, 10:20 PM
I use simple green or superclean. The issue with superclean is that it will cause damage if you forget it on there. Simple green and a brush will get it off.
smokinjoe73 is offline
Old 03-13-2017, 01:00 AM
Good old fashioned kerosene and an old toothbrush work for me.
After that polish the rim to put a coating of polish on it that makes it easier to clean off the next time.
With the other parts use kerosene and a brush , wipe off with a rag and spray with wd40 etc .
consistency is the key here, let it build up and it becomes a major chore, do it regularly and it's a snack !
kenmoore is offline
Old 03-13-2017, 11:39 AM
WD40 here and a toothbrush if it's thick. Usually a well soaked WD rag will get it.
Wolverine is offline
Old 03-13-2017, 03:32 PM
KLR996's Avatar
Yup. My first hawk was well maintained and I didn't have this issue. This one I just picked up... It needs some TLC.
Thanks all for the suggestions. I *have* WD, so I guess I have a date w/a toothbrush tonight. If that doesn't work, I'll step up to some other options.
KLR996 is offline
Old 03-14-2017, 05:53 AM
Thats me as well, then wash the bike to remove the Wd 40
E.Marquez is offline
Old 03-25-2017, 01:48 PM
KLR996's Avatar
Thanks guys. WD did the trick.
KLR996 is offline
Old 03-25-2017, 01:58 PM
WD is short for "water displacement"
Just a fun fact.
Old 03-25-2017, 02:22 PM
KLR996's Avatar
Just a fun fact.
That explains why my dad useta say "GD!" all the time... He HATES grease.
KLR996 is offline
Old 03-25-2017, 02:29 PM
water displacement 40th recipe!
Old 03-27-2017, 03:15 PM
WD40 is machine oil, kerosene and perfume...
Skip its cost and just put kerosene in a spray bottle. For thick muck use a plastic scraper judiciously. Simple Green can burn paint too.
Waxing after is a good answer but WD40 and kerosene do not need to be washed off, in fact they impart some non-stick.
skokievtr is offline
Old 03-27-2017, 05:27 PM
You sure there's no fish oil in it?
Old 03-30-2017, 07:28 AM
No, or according to one group with a gas chromatography (GC) and mass spectroscopy (MS)
this group says otherwise.
https://www.wired.com/2009/04/st-whatsinside-6/
Old 03-30-2017, 04:01 PM
That was sarcasm...
Old 03-31-2017, 06:04 AM
That was sarcasm...
The sarcasm Font tag must be broken...
thefauxnarchist
Forum Feedback
10-05-2010 03:55 PM
viperkillertt
04-21-2009 10:20 AM
ripvanwinkle
12-12-2008 07:00 AM
EngineNoO9
04-27-2006 07:20 AM
Quick Reply: ARGH! The Grease!
