WOW Another CCT Thread
Old May 21, 2010 | 06:11 PM
Bytes's Avatar
Bytes
Bytes is on a distinguished road
Red face WOW Another CCT Thread
I decided to order some APEs instead of modifying the original CCTs. They got here and I got the bike all prep'd. Tools cleaned and ready, all laid out nice and neat. I went in and re-read all the pertinent posts on CCT replacement, especially the Calitoz thread. Fantastic step-by-step BTW. I take my time, double and triple checking everything as I go. I get everything back together, double checking the fuel tank hoses. Put the key in and fire her up. She runs for about twenty seconds and dies. I pull the tank and make sure that the hose connections are correct and give her another try. No go. WTF? I reverse the vacuum hoses and give it another try. No go. I pull the tank and out of desperation I check the coils and plugs. Everything's right down the middle so I know it's a fuel problem. So I get all the tank hoses hooked up and try again. No go! My wife hears me throwing a tantrum and comes out to see what is wrong. She's about 5'0 and very petite so I have her reach under the tank when I pull it up to make sure nothing came loose. Before she sticks her hands back there she has a quick little peek and looks up and says "that thingy looks like its turned to off". OMG!!!!
All's well now, and the hawk is running great. Not so many rattle noises emanating from the engine!
Thanks to everyone here that has written about CCT replacements. Much more comforting taking on a project like that having a few subject matter experts backing you up!
Old May 21, 2010 | 06:22 PM
Congrats! And it's always the simple stuff that gets you.
Old May 21, 2010 | 07:02 PM
residentg's Avatar
check both ends of the hoses. Is the vacuum hose attached to the rear cylinder manifold, or did it pull off? Did you check the photo for hoses in the KB?
Old May 21, 2010 | 07:41 PM
Bytes's Avatar
Bytes
Yep... I took pictures from start to finish, all was perfect with the exception of one thing. The petcock valve was turned off. Live, and hopefully learn
Old May 22, 2010 | 07:15 AM
rich.m's Avatar
rich.m is on a distinguished road
I had the same problem and it turned out to be that I had the vacuum hose on the bottom nipple (no hose goes on that nipple) it goes on the small nipple facing you when you are on the left side(drive chain side) of the bike.
have a look it might be your problem
NHSH
Nov 12, 2013 09:36 PM
malken00
Aug 2, 2010 05:33 AM
midijunky
Nov 10, 2007 11:07 PM
Fish
Oct 13, 2007 01:56 PM
3D02
May 23, 2006 08:04 AM
