Worn carb slides?
Old Oct 10, 2008 | 11:18 AM
Little_Horse's Avatar
2nd mouse gets the cheese
Worn carb slides?
So I have searched and cannot find any specific thread about worn slides, I have heard other mention it, but am curious if my symptoms fit with this problem, I also would like to know if anyone has a way to check slides to make sure they are operating right.
Heres my problem, first of all it is progressivly getting worse, earlier this summer I noticed a very slight lean outish type stumble at 3500 to 4000 rpm. Its not noticable past there. I didn't change anything on my bike, it was stock carb parts. I took it to the shop they fubared it, and installed a dynojet kit fubared that, long story short I fixed all of their mistakes but am back to the original problem I just mentioned although now it is getting worse, much more noticable also from 2500 to 4000, its the same problem but with the dynojet needles and the original stock jets. I have 44k miles the slides are original and show wear, when I move them by hand the seem to operated ok, although on my friend's hawk his slide much better, his bike has 10k miles. Before I throw down $90 on each slide how can I confirm if this is really the problem. Also I would like to stear this thread away from jetting concerns and try to answer things related more to wear. I don't see how a problem would exist between the old jetting and the new and be exactly the same unless a shared part is worn out i.e slides, or my main jets since I am still using the original ones. I have tried alot of different jet setting and it changes the way it runs but does not elimanate the problem. Thanks all happy riding.
Old Oct 10, 2008 | 11:49 AM
PUSHrod's Avatar
If your slides rattle in the bores, then they MIGHT be worn. In 100K miles on airhead BMWs with their vacuum slide Bings, I never found slides that were worn to the point of needing replacement. Slide needles that had worn from contract with the jets, leaking diaphrams, cracked and leaking carb boots and other ills accrued with age. But not worn out slides.
I suggest going the free, then cheap, then more expensive route.
Search for a vacuum leak.
Is the petcock vacuum line installed correctly and not kinked?
Balance the carbs to one another.
Make sure that the ignition timing is advancing when the throttle is rolled on. Are you getting a good signal from the throttle position sensor?
I also doubt that its a jetting issue and I'll bet when the gremlin is exorcised it won't be because of money spent on parts.
Give us an update on progress.
Old Oct 10, 2008 | 12:02 PM
I have tried all of those things, even replaced the intake boots for added assurance none of those things fixed the problem, some of them did make it run better, but did nothing to aleave the original problem. I read on post about worn emulsion tubes, but was left very confused some people saying it was replacable and some saying it wasn't I am going to dig deep into the carbs later its gotta be a worn out part.
Old Oct 10, 2008 | 09:54 PM
filter69's Avatar
Thats Mr Dill hole to you
You are reinstalling those slides with a good spray on silicone lubricant right ? not dry,or oil,or snake oil..
Sounds silly but a good douche'in with s good silicone spray may solve your problem...
Just an idea.
Old Oct 10, 2008 | 09:58 PM
What mods have you done to your VTR?
What maintinence has been done?
Old Oct 11, 2008 | 08:19 AM
trinc's Avatar
corn,
go down to EDR performance and talk to chris. he rides a superhawk. is he a good mechanic ??? well, he was a honda HRC tech !
a baseline dyno run will chart your a/f ratios... may save you a lot of time.
tim
ps. did you read on the factory pro site about using the long emulsion tubes ?
btw: what shop did you take it to ?
Old Oct 11, 2008 | 09:16 AM
I took it to beaverton honda, will never do that again. If I ever do take to another shop it will be edr I have considered taking it in there but have not enough coin right now. Also as far as mods just a dynojet kit and a bmc air filter, I have tried a stock filter too, no difference I have tried lubing the slides with a multipurpose oil I could not tell if it helped because I really notice it more in traffic and I did this and ripped on it for a nice ride so I can't confirm but I will try a silicone spray as well just to see. I know they may not be worn but it sure seems like the symptoms it would make if the slides aren't lifting enough in the low end, feels like a lean stumble then when you get past it it runs just a hair rich from my needle setting being so rich in an attempt to aleviate the problem. I will save some money this winter and take it to edr but for the meantime I will keep trying things, thanks for the ideas and imputs I wil try them all. I will probably rip into them sometime today, but its sunny so I may ride.
Old Oct 11, 2008 | 12:21 PM
trinc's Avatar
i would still look at the jetting - its right in the transition point from pilot to the needle. try pulling the choke out a little bit & see if it makes it better or worse.
tim
rr-rider
Sep 22, 2012 11:04 AM
rz_racer_69
Mar 2, 2012 09:12 AM
zmaniv
Aug 20, 2011 12:09 PM
zmaniv
May 31, 2009 06:39 PM
Shortlived99
Apr 22, 2008 07:13 AM
