Wont turn over after new R/R
Old Dec 9, 2011 | 06:35 PM
aja's Avatar
aja
I replaced my R/R today with one I got from Partsman. After installing, when I press the start button there is a buzzing coming from the starter relay. I checked the main fuse and it is fine. I started her yesterday with the old R/R with no problems. I am not home right now as I had to leave before I could trouble shoot, however I am looking for suggestions on what to check. When I get home I will check all the connections and try to short circuit the relay to see if I get anything, but it doesnt make sense that it would be fine yesterday and not today. So, any ideas on what to check other than what I said?
Old Dec 9, 2011 | 08:13 PM
Was it a stock replacement? If so, try the old one and see if it starts okay. You may have gotten a bum part.
Otherwise, check the wiring. Did it require rewiring the connection? Did you check battery voltage and ground connections? Backtrack, checking everything you did to install the new R/R.
Old Dec 10, 2011 | 12:20 PM
aja's Avatar
aja
It was a stock replacement from a 2005 with 5k from what I was told.
I hooked up jumpers to it and it turns over but won't fire up. It tries to then dies, choked or not.
Old Dec 10, 2011 | 01:32 PM
Partsman's Avatar
Partsman is an unknown quantity at this point
aja, the r/r came off a running Super Hawk.....Make sure your battery is charged all the way. Sometimes a bad r/r can make the battery go bad....get your battery checked. If your battery is bad I have a good one I can send you for free.......any questions give me a ring....Sent you a PM
Old Dec 10, 2011 | 01:40 PM
aja's Avatar
aja
Partsman,
I just put a new battery in and still won't start. It turns over now but nothing else. There is a pretty strong gas odor coming from the exhaust when it cranks, so I think it may be flooded, but I've never had anything not start eventually. I tested the r/r and its good so that's not the problem. I did get it to start for a second but being cold it died.
Any suggestions? I'm at a loss for what to check now.
Old Dec 10, 2011 | 02:04 PM
Kill switch?
Not trying to insult, but it happened to me once. I never use the kill switch, but it got tripped while moving it around. I was in the mountains and thought it was just flooded at first.
You might want to pull the plugs and make sure you don't have a load of gas in the cylinders. Then try starting with the throttle open to clear the flood, if that's the cause.
Old Dec 10, 2011 | 02:14 PM
Partsman's Avatar
VTRsurfer....... Happened to me as well....what a bitch......LOL
Old Dec 10, 2011 | 02:27 PM
jay956's Avatar
i forgot to connect the ground once
Old Dec 10, 2011 | 02:49 PM
CrankenFine's Avatar
I assumed everybody gets fooled (once) by the kill switch on our bikes.(me too)
Old Dec 10, 2011 | 03:09 PM
Drained an entire battery on my shadow once doin that
Old Dec 10, 2011 | 04:13 PM
aja's Avatar
aja
Ok I feel dumb now.
No gas in bike. I know I know, rookie mistake. Now I know my gas light doesn't work now though.
Partsman, thanks! If anyone is looking for parts, I would suggest partsman. I got the part really fast, it was packaged great, and he (Gareth) even gave me his number to call him for help. Thanks again!
Old Dec 10, 2011 | 04:36 PM
Tormoz's Avatar
Tormoz is on a distinguished road
Originally Posted by aja
Ok I feel dumb now.
Curious, how do you explain the buzzing you heard from the starter relay? (In your first post.) So, is it starting now?
Old Dec 10, 2011 | 04:53 PM
Wicky's Avatar
From experience the starter relay will just make a click / buzz if not getting enough umph from the battery if it is if f*cked, loose connection on battery (vibration can loosen up bolt) or if the connector to the starter motor is corroded under the rubber hood (here in the UK it is essential to keep it greased up/vaselined up in salty winters).
Probably in this case from repeatedly turning it over till battery was low. - so enough to activate the starter relay but not enough umph to keep turning the starter.
Old Dec 10, 2011 | 06:30 PM
aja's Avatar
aja
Exactly. R/R fried the battery, I got a new one (and gas) and it fired right up
Gabe
Mar 19, 2015 10:10 AM
Mr.Lojo
Feb 7, 2015 02:48 PM
BigJMerc
May 4, 2011 12:14 PM
uchi
Apr 16, 2010 03:25 PM
viperkillertt
Jun 21, 2009 07:41 PM
