Wires crossed on R/R swap?
Old Dec 12, 2008 | 02:39 PM
supermarto's Avatar
Wiring for a generic 3 prong flasher relay?
I decided to install a generic turn signal relay to make the Buell blinkers I have work with the flush mounts up front (they had different blink rates, I thought this would make life easy) I don't think I wired it correctly and it blew the fuse for the turn signals.
SO while I am at it, anyone know which wires from the turn signal relay would go to the Load, Power and + or X on the generic truck flasher relay?
Old Dec 12, 2008 | 03:01 PM
ripvanwinkle's Avatar
aka sirch345. vtr1000.org
ripvanwinkle is on a distinguished road
Just a thought did you remember to put back the earth wire under one of the fixing bolts?
As long as you followed the sticky instructions for the correct fitment of the red and green wires it will be wired correctly, but double check that you had the rectifier the correct way up as the sticky shows when connecting those two wires.
Chris.
Old Dec 12, 2008 | 06:18 PM
txrb182sc's Avatar
On a Jonda, or a Hondo...
txrb182sc is on a distinguished road
Dude good luck with that electrical ****, I just kept messing around with the wires till it worked. Nothing blew up on me and I tried some crazy ****, anyways it works now, but my R/R has one extra prong that no wires go to.
Old Dec 12, 2008 | 06:26 PM
supermarto's Avatar
No, I got the R/R all hooked up and its fine, I just need to know from some electrical wizard out there which wires from the stock flasher go to the L, P, and X designations on the generic flasher relay... the only one I know for sure is L is "load". And I believe the X connection is also +, meaning juice from the battery. I thought P meant "power" but that is not what the P stands for. I am going to guess the Green wire goes to L, the Grn/White goes to the X, and the Gray wire goes to P... But I am out of fuses for the turn signal circuit and want to make sure before I hook it back up. I am thinking about just using the stock flasher and getting all my bulbs correct which would fix the flash rate (instead of using a $4 tractor flasher relay).
EDIT: I found out that the P designates "Panel" or "Pilot Light" for cars where there is an idiot light for the indicators... I am guessing now that there is no ground or green wire used, but that doesn't make sense either... If anybody knows, I am betting it's Tweety. Tweety man, if you read this, let me know what the deal is! PLEASE.
Old Dec 13, 2008 | 06:26 AM
supermarto, either you've completely changed you original question or I'm losing it???
Personally I think the clue is in the title:- Wires crossed on R/R swap?
Old Jul 26, 2009 | 06:31 AM
twidge's Avatar
twidge is on a distinguished road
relay diagram
hi
if you google norbsa02 theres a wiring diagram on the indicators page it might help
regards twidge
yruyur
Sep 15, 2009 08:53 PM
scarface
Jul 30, 2008 11:52 PM
J.J.
Sep 15, 2006 06:27 PM
thirty_ought_six
Aug 20, 2006 08:40 PM
jeremyjo
Jun 11, 2006 10:13 AM
