Carb Jets
Old Jul 25, 2009 | 11:04 AM
RuthlessButcher's Avatar
RuthlessButcher is on a distinguished road
Carb Jets
Now I don't know that much about carbs but from what I understand is the Main or Pilot jet fuels the carbs at low RPM and the secondary jet is either added or replaces the main jet at higher RPM. Now my question is does anyone know at how many RPM they switch. I`m trying to diagnose a hestitation at between 4 thousand and 5 thousand RPM when getting hard on the gas. I`m wondering if a needle or slide are sticking or perhaps this is normal. I just got my VTR in February so I`m full of questions still.
Old Jul 25, 2009 | 11:58 AM
Circuit_Burner's Avatar
guru of things sparky
Pilot jets are for idle and up to 1/4 throttle. But the overlap starts at around 1/8 throttle, and its effect on 1/4 throttle openings are minimal.
Needle hight (clip) and needle profile generally control a wider range in the middle, overlapping with the secondary jets (if they have them) and the mains, which govern fuel delivery starting(taper) at around 2/3 throttle and taking control mainly in the upper throttle openings.
If needles or slides are sticky, it can be felt when moving the CV plungers with your hand, and also visual inspection.
Old Jul 25, 2009 | 12:06 PM
I should have mentioned that the bike should be all stock except the K&N Filter. I say should because when I got the bike it suffered from a serious flat spot between three and 4 thousand RPM. The previous owner performed a bafflectomy and installed a dynojet kit and the Ducati dealer I bought it from replaced the cans with stocks and were supposed to stock the carbs but I remember the tech saying he could leave the jet or jets in but blamed the steep taper on the dynojet needle for the flat spot which I hated because I ride with my kids on the back and it always chugged in mid corner.
Old Jul 25, 2009 | 12:17 PM
Try the stock air cleaner element, if it clears up, you know what direction to go.
K&N filters only produce a wide powerband when jetting is just right ( which it rarely is )
I ran headers, 2 bros cans, cam profile mods, jetting kits ... with a stock filter.
Runs best here where Im at with the stock filter.
Old Jul 25, 2009 | 02:50 PM
The K&N filter needs jetting changes, otherwise it produces a big hole in the powerband, not an increase at all... And stumbles at around where you are experiencing them...
If you want too keep the K&N (for cleaning&re-cycling) you can try adding in the plastic lip that the stock filter has and see if that helps... I'm trying that right now... and it seems to be better... But at this point that is subjective "seat of the pants" feel...
Old Jul 25, 2009 | 06:07 PM
right on thanks for the info. I think I will pick up a stock filter from what I hear it runs smoother and tourqier
Old Jul 25, 2009 | 06:55 PM
Gregw's Avatar
Hi Tweety,
Do you have a picture of that lip (and/or dimensions)? I bought my bike with the K&N so I don't know what the stock filter looks like. Thanks.
Old Jul 25, 2009 | 11:12 PM
+1
I tried a K&N in my CX500 with 2 into 1 exhaust 25+ years ago. It lost midrange punch, so I went back to the stock air filter 1 week later.
Old Jul 26, 2009 | 12:09 AM
Originally Posted by Gregw
Hi Tweety,
There is some info/link to pics here...
https://www.superhawkforum.com/forum...3Bn+filter+mod
https://www.superhawkforum.com/forum...amp%3Bn+filter
Old Jul 26, 2009 | 09:29 AM
Gregw's Avatar
Thanks Tweety,
Makes me wonder if an air dam below the filter might help, placed between the velocity stacks. That might keep the two cylinders from playing tug-o-war with the air.
Old Jul 26, 2009 | 03:49 PM
I saw BMC makes air filters like K&N has anyone seen one to see if it has the Fin like a stocker?
Old Jul 26, 2009 | 05:07 PM
LineArrayNut's Avatar
I could ride in
my BMC street (not installed) doesn't have fin
Old Jul 26, 2009 | 11:47 PM
shayne's Avatar
Sounds like you need to understand how your carbs work. Factory Pro have a very good section on CV carbs, so have a read of their hard work.
http://www.factorypro.com/tech_tunin...m_engines.html
loserbaby
Sep 8, 2007 07:31 PM
ClevelandSuperhawkRumble
Apr 27, 2007 11:09 AM
Zedicus
Mar 29, 2007 06:59 PM
EngineNoO9
Feb 17, 2007 03:03 PM
Dave Wicks
Jan 10, 2007 04:52 AM
