will only start in nuetral.....?
Old Nov 25, 2005 | 05:06 PM
USAFrider's Avatar
USAFrider
Hi I am a new SH owner, just picked her up a couple days ago. The bike will only start in neutral, instead of just being in first and pulling in the clutch. This is my 8th bike and I have never seen a bike that starts only in neutral. Also I know there have been a lot of questions about oil, how ever I live in central cali where it is in the 60s all the time and I put in mobil 1 20/50, is this ok as long as I treat the clutch nice? Also what is the highest mileage heard of on an SH? The bike runs great it has 42,000 miles on it but when I went to see it i couldnt believe how well it runs. Honda is amazing.
Old Nov 25, 2005 | 06:30 PM
perhaps the kickstand switch is malfunctioning... try jumping the switch.
Old Nov 25, 2005 | 06:36 PM
superbling's Avatar
The bike will not run if the side stand is down (or thinks its down) while the bike is in gear.
Another part of this lockout loop is the clutch switch. It could be loose or dirty. Remove it and give it a good shot of wd40 and clean it up.
Old Nov 26, 2005 | 01:16 AM
marmaladedad's Avatar
Hmm?
Just to clarify (as this problem is afflicting my SHawk too), the clutch switch is the part that gets pressed in when the lever is pulled...?
Old Nov 26, 2005 | 04:06 AM
woodman's Avatar
woodman
Re: will only start in nuetral.....?
Yes
Old Nov 26, 2005 | 09:42 AM
Hmm?
Thank you.
Old Nov 26, 2005 | 10:40 AM
USAFrider's Avatar
USAFrider
I'm sorry so the clutch switch is where?
Old Nov 26, 2005 | 05:49 PM
superbling's Avatar
It's activated by the lever and makes the clicky sound you hear with the engine off when you pull the lever in. It's underneath the perch (holder). One screw holds it in. The two wires are usually hard to get off so I don't and just squirt the wd40 in any hole and around the actuating pin and work the lubricate in.
If the screw is loose, then the switch may be misadjusted and therefore sending a "clutch engaged" signal all the time.
Old Nov 29, 2005 | 10:24 PM
USAFrider's Avatar
USAFrider
turns out I just needed to adjust my clutch lever. It wasn't letting the switch work properly.
Old Dec 2, 2005 | 12:15 AM
EngineNoO9's Avatar
so it will allow you to start it with the clutch pulled in?? hmmm i need to check mine...
Old Dec 2, 2005 | 07:38 PM
USAFrider's Avatar
USAFrider
yeah it works now I just adjusted the lever untill I heard the clicky sound. I figured it out after cleaning it and finding out there was nothing wrong with it.
Old Dec 25, 2005 | 10:08 PM
Speed_Demon's Avatar
Mine is doing the same thing. The clutch switch and the wires up to the main harness are good.
Could this be a malfunctioning side stand or more likely a break in the clutch switch wire in the main harness?
Old Dec 26, 2005 | 06:33 AM
By good.. do you mean they "look
" good.. Or you put a meter on them and know they are good?
Troubleshooting anything, but most importantly electrical faults,, have to be done methodically, and without skipping steps. Otherwise you will chase your tail,, replace unneeded parts,, and still have the problem.
Confirm the switch is working with an ohm meter, confirm the wiring all the way to the connectors does not have an open. Is your no start an intermentant deal? Or always?
I checked the circuits with an ohm meter. The problem isn't intermittent, it has never started in gear with the clutch in. The main harness looks good but I haven't tracked the wires down yet.
Montana
Aug 7, 2010 07:12 PM
Montana
Sep 9, 2009 10:30 PM
j_bud2007
Jun 25, 2009 12:51 AM
vtrlvr
Sep 11, 2007 04:05 PM
andrewlondon
Feb 1, 2007 03:10 AM
