Will not stay in second gear
Old Aug 24, 2012 | 01:12 PM
lukenukem47's Avatar
A Superhawk I'm looking to purchase pops into neutral from 2nd gear with any considable amount of gas. What could be the cause and what do I do to go about fixing it.
Old Aug 24, 2012 | 01:25 PM
Jack Flash's Avatar
Well take off, eh.
Negociate pricing since you will need a transmission job. Minimun, change of fork...but usually leads to alot more.
Old Aug 24, 2012 | 01:53 PM
gotta_gofast's Avatar
gotta_gofast is on a distinguished road
Bent shift fork. Cheap part to purchase but requires you to split the cases. However, shift forks don't just "bend" unless the trans was abused. And generally people don't just abuse a trans, they abuse the WHOLE bike. So, my advice is to keep looking for a cleaner bike.
Old Aug 24, 2012 | 02:20 PM
Thanks guys
Old Aug 24, 2012 | 02:28 PM
Walk away
Old Aug 24, 2012 | 05:01 PM
saige's Avatar
the boss
Unless its crazy cheap at this point,just walk away.
Old Aug 24, 2012 | 05:23 PM
GTS's Avatar
GTS
Seasoned tech
Could be shift fork, or could be the gears themselves. Hard saying until you get into the transmission. The nice thing about these bikes is you don't have to drop the whole engine or tear it completely apart to replace the transmission. You can simply unbolt the bottom half of the engine, granted this does require removal of the clutch and rotor etc, and drop it down with the transmission and replace the needed parts.
Old Aug 26, 2012 | 10:05 AM
JamieDaugherty's Avatar
For sure the shifter fork for 2nd gear is bent. Most likely it was bent because of worn dogs on the mating gears. Plan on a case-split job and several parts needing replaced. If it's cheap it still might be worth it. Good luck!
uchi
Nov 14, 2022 04:49 PM
CruxGNZ
Jan 13, 2016 07:19 AM
Vega (streetfighter)
Jun 12, 2014 03:10 AM
codybrown
May 3, 2013 06:28 AM
