Where should I get power from?
Old Sep 27, 2009 | 09:54 AM
j shizzy wizzy's Avatar
mildly retarded
I am about to mount a GPS system on my bike. Should I wire the harness to the batt. directly? or should I go into the Fuse box? or should I splice in somewhere? the kit I have has an inline fuse already. I've never done any accessories like this before.
Thanks all!
Old Sep 27, 2009 | 10:16 AM
uchi's Avatar
im a fan or wiring right to the battery. that way your not gonna draw anything else from the fuse box. make sure you use the inline fuse for it
Old Sep 27, 2009 | 11:42 AM
gboezio's Avatar
To the main relay using the fuse, or splice the medium sized red wire that goes from the main relay to the fuse box, this is mostly to shut the GPS off when you pull the key.
You could use the lighting circuit since a GPS use close to no power at all.
Old Sep 27, 2009 | 05:59 PM
mildly retarded
I ended up going to the battery. I may use the third eye wires in the future. I think it would look cleaner not having wires running over my frame... thanks for the replys guys!
Old Sep 27, 2009 | 07:53 PM
uchi's Avatar
i wired my hids right from the battery, taped the wires in black electriclal tape and hid everything behind the frame zip tieing it to things here and there. cant even tell its there
Old Sep 27, 2009 | 08:07 PM
shizzy, where've you been? I thought you tried to recover your stolen mountain bike and got whacked or something.
Good to see you back.
Old Sep 27, 2009 | 09:43 PM
mildly retarded
Hahaha! Good to be back! I've become a corporate *****! My new job is kicking my butt. I've been so busy its crazy! 50 - 60 hrs a week. But I mustn't complain, thank god i have a job and a good one at that! I work for Stanley now. I install automated door systems. As far as the bike I will never see that money....hes a POS.
Old Sep 29, 2009 | 05:51 PM
shayne's Avatar
I am a believer in having proper fused circuits switched by the ignition for all accessories.
Except for GPS's.
I wired mine staright from the battery, so that each time I turn the key off it does not shut down and need to be restarted again. You can't forget about it of course, but if you are leaving the bike parked for a while I would remove the GPS so it did not get stolen anyway.
nykuryu
Apr 18, 2011 10:01 PM
motojoe
Aug 10, 2009 10:51 AM
Blkbird
Oct 19, 2007 08:13 PM
Otto Man
Jun 28, 2007 08:16 AM
EngineNoO9
Feb 20, 2007 08:24 PM
