What clusters can I use on my fighter project?
I have decided that I can't use the stock cluster because its too big and destroys the look of the bike. I've seen small RC51 clusters used but the tach signal was wrong. What clusters are compatible and very small? I know the plugs won't match. Otherwise I think I'll end up with a bike speedo (BC800), a mini tach, an array of custom lights for fuel/neutral/sidestand/highbeam, and maybe a small mechanical temp gauge. I would like to do away with the temp gauge but with a custom cooling system I think I should keep tabs on it.
It had something to do with the VTR being analog and the RVT being digital. It may have been a different functionality. I don't really remember.
Let me know what you come up with. I've been contemplating doing something like the chromed bullet-shaped guages from the naked Bandit. I don't know about the electrical side of it, but shouldn't be too hard to fabricate an adjustment. Way back in the dark ages I actually completed an electrical engineering degree. I think I still remember Ohm's Law....
Re: What clusters can I use on my fighter project?
Hey Speed_Demon, check this out...
No gauges required on the bike... They are all on the HUD (Heads Up Display)
see www.sportvue.com
Here is what I'm running.
https://www.superhawkforum.com/viewtopic.php?t=1178
'01 929 gauges, the new CBR1000RR gauges will likely work as well since Honda is pretty consistent with their wiring, just not the plug ins.
I have had bo problem with the tach signal and verified accuracy with a Fluke tach.
Ditto with the digital temp gauge, also accurate.
I did have to change the fuel level sending unit to the old style low fuel level sender ( No float )
Have fun with it.
Kai Ju
Have fun with it.
Kai Ju
Sportvue for 135 plus ship
http://www.botswana-tourism.gov.bw/c.../language.html
I just found these. Thought you guys might be interested. Pretty sick. Here is a review also
http://www.twowheeltouring.net/Revie...MC1_Review.php
I am keeping my eyes opened for cheaper ones. Maybe 75 bucks and i would be very happy.
Have fun with it.
Kai Ju
Have fun with it.
Kai Ju
Tweety,
I'm using cbr1000rr gauges on my 96 VFR. Previously I had tried a koso rx1n gauge and used one of its extra temp sensors. All other functions on the RR work except the speedo readout. It's WAY off and will need a correction box.
BTW, I can swap back/forth from KMH to MPH on my set.
Tweety,
So far I have only tried it for a few km when fiddeling...
But I have either completely missed the ability to swap or it's not there in my case... how is it done on yours?
But I recently mounted CBR600 RR gauges on my CB-1.5 and had to use a late model temp sender to work with the gauges.
Since I didn't have enough room to drill out and tap the thermostat housing I mounted the sender in the drill press and filed/sanded the O.D. until I was at the right size to recut the threads to fit the existing hole. Works like a charm.
Kai Ju
