Well I suffered a CCT sudden failure
Old Sep 17, 2008 | 06:28 PM
Kendrick's Avatar
The Hypno-Toad
Unhappy Well I suffered a CCT sudden failure
The bike started making a rattling noise on the freeway. I drove for a few minutes wondering what the noise was when it dawned on me. It was the dreaded ball bearings in a paint can CCT failure noise. I headed for the freeway exit ramp and as I slowed the bike stalled. When I tried the starter while still coasting in an effort to make it to city streets the engine would not turn. So...is this usually a total lose, or is it just hung up and could be repaired. I hate to say it but if it's a total lose this is my last envolvement with superhawks.
Old Sep 17, 2008 | 08:20 PM
Sablotny's Avatar
ReNoob
Sablotny is on a distinguished road
Sorry to hear that. No worse feeling than having your ride go down while riding it. How many miles on your bike? Have you verified that was the deal?
Old Sep 17, 2008 | 09:28 PM
Streaky's Avatar
Streaky is on a distinguished road
I wouldn't say total loss.
Take the heads off and see what happened. I know it's a pain, but... worth the effort.
Old Sep 18, 2008 | 12:55 AM
Instead of investing so much time into it, see which cylinder you can get to TDC. The cylinder that you cannot get to TDC is the culprit. Remove it, take some carb cleaner and shoot it down the intake and exhaust tract. Look on the combustion side to see who's leaking... those are your bent valves. Take it to your local shop, have them replace the bent valves. Order up some A.P.E. cct's and never worry about this again.
Old Sep 18, 2008 | 05:05 AM
Cleveland's Avatar
Post Whore Junior
This may be of use to you.. https://www.superhawkforum.com/forum...ad.php?t=16159
member here selling an entire engine... low enough price to make it worht a look..
Old Sep 18, 2008 | 06:01 AM
Kendrick's Avatar
The Hypno-Toad
I'm not sure what I want to do yet. By the time I fix it the riding season will be over. Right now I'm more interested in unloading so I can get anything to ride the rest of the season. In my world riding is more important than the hawk.
Old Sep 18, 2008 | 07:23 AM
CentralCoaster's Avatar
If you destroyed the engine, why is this your last involvement with superhawks? You know CCT failure was eminent if you've been on here for any amount of time, but you gambled on it. That makes as much sense as dumping your g/f because you got her pregnant after boinking her without protection.
There's a low mile engine for sale for $350 on here. You won't get squat for the bike trying to sell as is.
Old Sep 18, 2008 | 08:06 AM
Kendrick's Avatar
The Hypno-Toad
Your analogy makes no sense. The bike should have been engineered properly from the factory. In the two years I've had this bike I've had the R/R failure and now the CCT. As an engineer myself it does not make sense to have any devotion to a machine that requires fixing from the factory. Aside from that I haven't decided what to do with the bike.
Old Sep 18, 2008 | 08:46 AM
MisfitToy's Avatar
Shredding Asphalt
you could always part it out if you need too. best thing to do if you have an inop vehical and want to get some sort of money back
Old Sep 18, 2008 | 09:22 AM
Erik S.'s Avatar
As an engineer, you should be able to see that the analogy is perfectly on point.
If it is a known possibility, the pregnancy or cct failure, and you don't take the necessary precautions to avoid the problem, pregnancy or cct failure, then it is a weak or lame move to get rid of it because the possible problem occurred.
You have over 200 posts on this bulletin board, so it should be safe to assume that you have spent an adequate amount of time on this bulletin board, and knew of the possible problems with the motorcycle that you currently own.
So in another analogy, if you had a child with a birth defect (known defect from the factory) would you not try to fix it?
Anyhow, good luck with your choice.
Old Sep 18, 2008 | 09:27 AM
HawkRider98's Avatar
As an engineer you probalbly did your homework before purhcasing and should have known about the "factory defects" before purchasing. Yet you purchased anyway?
Old Sep 18, 2008 | 09:44 AM
Kendrick's Avatar
The Hypno-Toad
Wow, rough crowd. Actually i impulse bought the bike. I had read that many people had had no problems with the CCT. In light of that and never having heard any unexpected noises from the bike I did not worry about it. I didn't expect the thing to go from fine to broken in a split second.
Okay continue to post how I should have known better...
Old Sep 18, 2008 | 10:02 AM
Erik S.'s Avatar
Rough? perhaps.
Loyal? Definitely!
If you had stated originally that it was an impulse buy, and not gone the "engineer" route, probably would've been a whole different scenario.
My $.02 for what you should do: keep it, fix it, ride it. Unless you ride all year, your season is at the tail end isn't it?
Old Sep 18, 2008 | 10:11 AM
runrowdy's Avatar
runrowdy is on a distinguished road
What's with all these engineers lately? Shouldn't they be buying BMW's?
Old Sep 18, 2008 | 10:19 AM
Engineers, not managers they actually do something, and people who actually do something never get paid what they are worth, it's those sitting around telling them the wrong thing to do that get paid..
Old Sep 18, 2008 | 10:25 AM
SPRHK's Avatar
my e-penis is huge!!
SPRHK is an unknown quantity at this point
Rule #1
If it has **** or wheels, it WILL give you problems
Rule #2
If it is something mechanical, It can and will eventually break.
Just a little common sense.
Old Sep 18, 2008 | 10:33 AM
runrowdy's Avatar
LOL Rule #1 is sooo true and common sense has nothing to do with engineers
Old Sep 18, 2008 | 10:36 AM
SPRHK's Avatar
AMEN brother!!!!
Old Sep 18, 2008 | 10:39 AM
Kendrick's Avatar
The Hypno-Toad
BMW's for cars, I prefer more affordable motorcycles as they are much easier to damage. Tip overs, crashes, etc. I've had my share. (Oh yeah and Jeeps for four wheel drive)
Well no matter what I do my season will practically be over before I get it sorted. Once I'm done feeling let down by my bike I'll take it apart and see what's wrong with it. I haven't done much research yet, but do I have to drop the engine if I need to change the valves? If I can leave the engine in for any repairs I'm far more inclined to do them.
And I was only a couple days away of being done working on all my vehicles...
Old Sep 18, 2008 | 10:48 AM
1zeppfan's Avatar
1zeppfan is on a distinguished road
Taking up walking?
Old Sep 18, 2008 | 11:03 AM
Cleveland's Avatar
Post Whore Junior
you got to remember this forums is full of people who are passionate about this particular bike...
Old Sep 18, 2008 | 11:18 AM
sassage's Avatar
hey, leave us engineers alone
Old Sep 18, 2008 | 11:21 AM
PHxS's Avatar
Schnitzel
PHxS is on a distinguished road
I have the bumper sticker on my toolbox for all to see. As a mechanic, i've seen a lot of broken/problem items as well as plenty of stories.
Old Sep 18, 2008 | 11:34 AM
Kendrick's Avatar
The Hypno-Toad
Probably the first thing I learned as an engineer is not to bother defending myself. Just ignore them and it will get old after a while. Engineering the most useful and most made fun of profession.
Old Sep 18, 2008 | 11:46 AM
Yardstick's Avatar
Yardstick
What are you doing with just one bike anyway? Just buy something else to have fun with while the 'hawk is down. Once the 'hawk is back up and running well you have two bikes to choose from and a spare if one goes down again. Heck, I've got FOUR and I might be adding another this weekend. That'll be five if I can't sell my VTR or XR.
Old Sep 18, 2008 | 11:59 AM
Kendrick's Avatar
The Hypno-Toad
I know, don't think the tought didn't cross my mind last night. I'm running out of money and garage space though. I might pick up something cheap for the moment just so I don't lose the rest of the season, the problem is it has to be capable of making the 25 mile commute to work.
Old Sep 18, 2008 | 01:31 PM
LineArrayNut's Avatar
I could ride in
How many miles on your 'Hawk?
I think what folks are saying is the first time you do any real maintenance on the engine like a valve check or at least by 20K miles some APE manual CCT's need to be on there. That seems to be the consensus of opinion that I've read. Or the first time you hear ANYTHING funny grab some clutch and kill it.
Now, I've got about 5K on an '03 with autos still on it so I'm not trying to rag ya'...
Any 125 or larger dual sport will do 25 miles no problem.
Old Sep 18, 2008 | 01:36 PM
SPRHK's Avatar
Most of the engineers I have met are book smart and common sense stupid...........most of them, not all.
Old Sep 18, 2008 | 01:47 PM
mfast1's Avatar
mfast1 is on a distinguished road
I get paid to fix engineer's lack of engineering. The bike is a good bike and worth fixing . But to each is own. good luck.
Old Sep 18, 2008 | 01:55 PM
Yardstick's Avatar
Yardstick
Curious what you mean by that dig exactly... being an engineer and all.
Engineers are not above making mistakes, but usually there are enough reviews and analyses performed prior to a production part that you rarely see the effects. Some will seem to slip through the cracks because you can't always predict the way the equipment will get abused.
