weird start issue
weird start issue
this has happened on 2 or 3 seperate occasions now. ill park the bike for a bit, stop to get a drink and shoot the breeze for a short while, turn the key, hit the start button and itll crank a few times and then feels like i let go of the button but its almost got a rough stop to it. happened a few times. what do you guys think? what should i start getting ready to replace?
Could be between the start button and the starter relay, squeeze a wire in a connector between the button and the relay trigger, plug a voltmeter and make it happen, if the voltage drop while you crank the push button may be bad, if not the starter relay gets tired.
