WD 40 vs gaskets
Old Jun 1, 2009 | 02:02 PM
merlyn's Avatar
merlyn is on a distinguished road
WD 40 vs gaskets
I ve heard that wd 40 affects the gaskets and I think it is not good to clean the chain(o-ring)! What is your opinion?
Old Jun 1, 2009 | 02:14 PM
http://www.webbikeworld.com/t2/motorcycle-chain-lube/
I'd use it but not let it sit on the chain for long.. Besides I don't clean every ride, I lube ever 500 miles or so, but only clean when it looks grungy. Might not be perfect, but a 530 chain is fairly hefty and takes time to wear.
Old Jun 1, 2009 | 02:33 PM
opsmgr's Avatar
opsmgr is on a distinguished road
Yeah, I lube the chain every 300 miles or more if it's been wet.
I clean the chain with WD40 on a rag (and some rubber gloves, it's a messy job) once or twice a year, or when the chain looks really manky/gritty.
Cheers,
Paul.
Old Jun 1, 2009 | 07:08 PM
Circuit_Burner's Avatar
guru of things sparky
WD-40 is more of a solvent than a Lubricant.
If spit wasnt corrosive, it would be a better lubricant than WD-40.
Old Jun 1, 2009 | 07:42 PM
Stevebis1's Avatar
Already discussed - about 2 months back. https://www.superhawkforum.com/forum...ght=chain+lube
read the entry by Crawdaddy. WD40 seems to do the trick for him and it has so far worked for me. I spray the chain and wipe it "dry" with a rag every other fillup. Can't quite work up enough spit...
Old Jun 1, 2009 | 08:08 PM
we are talking about cleaning the chain..
I use a chain wax for a lubricant.
Old Jun 2, 2009 | 02:15 AM
gboezio's Avatar
Water Displacement compound # 40, it's name says it all.
The most in depth WD-40 thread ever
http://www.advrider.com/forums/showthread.php?t=345397
If not enough search for the part two
Old Jun 3, 2009 | 12:48 AM
merlyn's Avatar
Thanks!Very interesting link!
Old Jun 3, 2009 | 01:57 AM
opsmgr's Avatar
Yep. Me too, but it wasn't obvious in my post. Chain lube to lube, and WD40 to dissolve the manky lube.
I don't use chain wax, as I find it too gloopy, I use Silkolene lube, which is thin and not too tacky.
Cheers,
Paul.
Old Jun 3, 2009 | 02:15 AM
Bel Ray has this stuff my buddy sprayed on my chain last week at their shop, and its pretty awesome.
I dont know exactly what its called but its fairly new.
It sprays on real thin and runs easy, but within a few seconds it like dries and turns blue/white. Looks almost like paint when its on.
You can sure tell the spots you missed thats for sure.
I will find me a can this week and report back.
Reba
Jan 29, 2008 06:48 AM
vtwinlover72
Jun 23, 2007 12:18 PM
dpenix76
Sep 18, 2006 08:43 PM
mikenap
Jun 14, 2006 04:46 AM
EngineNoO9
May 23, 2006 09:27 PM
