VTR Dies randomly
Old Jul 21, 2005 | 11:48 PM
CTSmoto's Avatar
CTSmoto
VTR Dies randomly
OK, my friends 2003 superhawk has a problem that he drove out of the dealership with and they can't find anything wrong with it. I have ridden it several times and what I have found is that when decelerating if I pull in the clutch the bike dies. It starts right back up no problem. When I split lanes and pull in the clutch it just shuts off.
I have found that if I am accelerating and pull in the clutch as if to change gears but I don't change gears it wount shut off. Only when RPMs are dropping and clutch is engaged does it crap out.
WTF is going on here?
Mike
Old Jul 22, 2005 | 12:12 AM
caffeineracer's Avatar
caffeineracer
What's the idle rpm set at?
You may be able to fix the problem by just increasing the idle rpm by a couple hundreds.
This will lessen engine braking too, and that can make throttle control easier while cornering.
~Jeffers
Old Jul 22, 2005 | 12:15 AM
CTSmoto's Avatar
CTSmoto
Re: VTR Dies randomly
I have tried it up at 1500 rpms and 1700 rpms with the same result.
Where should the idle be on this bike?
Old Jul 22, 2005 | 06:24 AM
SlowHAWK's Avatar
CTS...
I don't remember exactly but I think I recall reading somewhere that "computer" will cut off the bike ignition if you pull in the clutch when driving over certain speeds???? Does anyone else recall this as well? (Or am I just crazy??)
J.
Old Jul 22, 2005 | 07:19 AM
jschmidt's Avatar
jschmidt
Idle is 1200 rpm. This is a common problem that was supposed to have been fixed by a change in the internal diameter of the carb boots in 2000. Some do it some don't.
AFAIK (despite lots of web theories) no one has found a perfect fix.
Old Jul 22, 2005 | 10:18 AM
kmm996's Avatar
kmm996
My 2000 VTR did something very similar. It would also die intermitently when I would pull in the clutch. I took it to my dealer and the Tech tore into it and could not find anything. He also rides a VTR so he started swapping parts from his to mine and found the rear ignition coil would quit when it would get hot. He put on a new coil problem solved. Just a Thought. It might be something to look into.
Old Jul 30, 2005 | 09:48 AM
scoop's Avatar
scoop
Check out this link, look for the item regarding bike stalling when pulling clutch in on the highway. Apparently it happens. Solution is not to do it.
http://webpages.charter.net/gnemish/index.html
Old Aug 3, 2005 | 04:54 PM
NOrrTH's Avatar
Mine used to do it before I disabled my PAIR system. Maybe a coincidence though.
Old Aug 3, 2005 | 05:47 PM
divingindaytona's Avatar
Remember stock is BAD!
kmm996 - Personally I wouldn't take my bike to that "tech".
He isn't a mechanic he is a parts swapper - there is a big difference. Anyone can swap parts.
Just my 2 cents
Old Aug 3, 2005 | 09:14 PM
kmm996's Avatar
kmm996
He may be a parts swapper, But I haven't had a problem since and that was 3 years ago. If he didn't swap the parts who knows if the problem would have been found. It fixed the problem and it has not came back. So in my book he did his job. So am I wrong in saying it was worth it?
Old Aug 4, 2005 | 01:55 PM
Not at all. I was just making a distinction.
If the guy does his job, more power to him.
Old Aug 4, 2005 | 08:40 PM
kmm996's Avatar
kmm996
Divingindaytona,
I like the idea of having a mechanic who rides the same thing as we do. He is familiar with the bikes characteristics(and it has a few unique ones) and he is not affraid to think outside the box when normal diagnostics fail to show the problem.
But thanks for your two cents.
meanhawk98
Mar 23, 2012 11:44 AM
McFixxx
Jun 4, 2011 08:32 PM
ripvanwinkle
Mar 11, 2008 09:11 AM
Philip
Jun 18, 2006 03:09 PM
inderocker
Sep 9, 2005 05:14 PM
