Very weird issue for me
Ok guys, i had the bike out friday and put about 80 or so miles on the bike just going to work. the issue i had and i am perplexed to why or what caused it.
i am on the highway on the backend of my trip and while cruising in 6th gear at about 70miles I lose all power, there is nothing on the gauges and the engine is off. as i float down the road it comes back to life with a huge backfire (expected) and i continue on my journey. about another 5 miles and it repeats same thing.
its a 2003 with about 14,000 miles on it.
Any ideas what caused this and how to not have it happen again??
ok i read some earlier posts..
could this be my regulater rectifier? if it is it looks to be a simple fix.
i am gonna get my manual and see what i can do to check out the voltage of the unit..bt if anyone has any other ideas please feel free to let me know..
It might be the tank ventilation tube routing. Is it all stock or has some rerouting of the tank tubes been done (due to removal of evaporation canister, for instance)?
My bike has died in the rain and occasionally after filling up. It runs again after opening the tank cap to allow more air in the tank - it's related to the hose routing.
Well yeah my gauges went out then came back on. that happened both times
The only thing i have done electric wise is change out the battery but i made sure my connections were/are tight.
The tank is all stock nothing done to the routing tubes.
I am starting to think the r/r is the culprit..
well, are you gonna check the R/R or what??? but coincidently i had this problem with my cb and the vent tube for the tank was kinked and no gas was draining down to the carbs, and then it would off of a sudden work again.
yeah i plan on looking at it today or tomorrow once i get out of work. Couldn't do it over the weekend cause i had my dishwasher decide to blow a hole in it and leak so i spent my weekend working on that. but once i get out of work i plan on doing it.
makes sense, sorry for the incident but GL with the check!
I am ordering the R/R tonight or first thing in the morning. I figure it is best to replace it anyway.
Whats puzzling me is that i am reading the posts and i am seeing allot of R/R issues, isnt that strange???
Not to fight/contradict everyone... but I don't think it's your R/R.... once the R/R does go, your running purely on battery power, so once things start to go out (dash, lights, engine), they stay out until you charge/replace the battery.
If it's shutting off then suddenly then kicking back on I'd do like Hawster recommended and check your connections to the battery, the ground and the sidestand switch as well... as if that's loose, it could shut the bike off, then allow it to kick back on when it gets moved agian.
J.
J.
yeah i checked the battery tonight and it is tight. I have an alarm on the bike (while i lived in Ft Lauderdale, had to have it) and made sure the alarm didnt interfere and the battery posts are not corroded.
I am going to check my r/r tomorrow once i locate my damn altimeter (brother used it and hasnt bothered to put it back)
what you smokin' to need to know how high you is?
apparently not enough...wife is trying to kill me with the damn honey do lists.... i havent had time to look at the bike. guess its a good thing it will be raining this weekend, i get to sit in the garage (maybe with the engine running a bit, just a joke)
