Vaccum Lines
Old May 28, 2020 | 11:16 AM
Kevin Schmidt's Avatar
Kevin Schmidt is on a distinguished road
Vaccum Lines
I have an 98 there are 3 lines at the bottom near the stator one of the lines got disconnected it was a little plastic piece at the end of it. My bike will turn over for 5 sec then shut off. I believe it goes to the carbs but i could be wrong i just dont know where it goes. Any help would be much appreciated.
Old May 28, 2020 | 11:30 AM
Wicky's Avatar
They'll be tank vent / overflow hoses to the base of the tank - best reconnect it esp the fuel related ones to help prevent gas getting onto the top of the engine.
If you 've had the tank off make sure the vacuum pipe is connected correctly on the petcock i.e not on the drain spigot pointing down but at the back pointing horizontally.
twist
Jan 31, 2013 04:14 PM
zbart1108
May 27, 2012 07:23 PM
Redone
Aug 4, 2009 05:22 PM
Shmittay
Apr 27, 2006 06:28 PM
willie
Apr 27, 2006 11:34 AM
