front brake lines
Old Jan 30, 2013 | 10:28 PM
twist's Avatar
front brake lines
So, I'm getting ready to buy braided brake lines and I question the use of the splitter bloc between the MC and the two brake lines. Some claim that by not using the splitter there is more wear on the lines at the calipers. I've done it on other bikes and never had any issues. I guess I want to know if there is any real gain in braking by omitting the splitter bloc. There is the rubber hose from the MC to the splitter so that might be an issue? I'd like to know what others have done in this regard. I want improved braking and I like the way the braided lines look.
Old Jan 31, 2013 | 07:40 AM
I have had the 2 separate lines on mine for 12+ years now with no issues and would recommend running that set up.
Old Jan 31, 2013 | 08:28 AM
comedo's Avatar
+1
Changing to two braided lines was one of the first changes I made. Removing the splitter may make the lines easier to bleed. Rubber lines deteriorate with time and should be replaced. You'll probably have a firmer feel at the lever if you use two braided lines rather that a rubber line to the splitter and two braided lines from the splitter to the calipers. I used a double banjo bolt with an included bleeder valve at the master cylinder.
Old Jan 31, 2013 | 09:27 AM
I'm not sure I've heard of this or understand it. Internal wear or external? I'm guessing external... more of a curiosity thing for me I guess.
Old Jan 31, 2013 | 11:13 AM
twist's Avatar
there have been some who claim the hoses get weak and can fail at the banjo bolt at the caliper, so it would be external. The motion of the forks being the main culprit. This would be especially so for duel sport bikes used on rough terrain a lot. I like the look but think it would work better coming direct from the MC with no rubber hose, no splitter and direct to the calipers.
Old Jan 31, 2013 | 02:41 PM
matt365's Avatar
Originally Posted by comedo
+1
I agree with Comedo. The splitter block can make it a pain to bleed properly.
The most expensive part of steel braided lines is the fittings. Most are sold with a double banjo bolt for the master, and two lines to reduce the amount of fittings needed. It'd be 6 otherwise.
Old Jan 31, 2013 | 04:14 PM
twist's Avatar
Looks like the splitter is going away.
F1 Fan in Nascar Land
Apr 25, 2007 11:43 AM
CNI Dawg
Nov 25, 2006 10:15 AM
CNI Dawg
Nov 18, 2006 04:42 PM
VTwin996Rider
Nov 1, 2006 05:43 PM
