unstable idle
Old Apr 29, 2010 | 08:07 AM
merlyn's Avatar
merlyn is on a distinguished road
unstable idle
After I tooked my bike from service(changed both cct after front failed) i hear a metallic clank from the front cylinder and the idle is verry unstable 300+ or -
Maybe they failed to aling the timing??or valves should be the probs??
Old Apr 29, 2010 | 09:11 AM
SPRHK's Avatar
my e-penis is huge!!
SPRHK is an unknown quantity at this point
I hope it wasnt a dealer that serviced this bike! I would take it back and have them fix it right. They may have the valve timing out. ALso, did they check the head, ot just replace the CCT? you may have bent a valve, damaged a piston, or a combination of things....
Old Apr 29, 2010 | 10:17 AM
residentg's Avatar
+1
Old Apr 30, 2010 | 02:13 PM
merlyn's Avatar
the noise from the front cylinder it s sounds like a ticking noise,maybe the new OEM CCT its not properly installed!what should I do first??
Old Apr 30, 2010 | 02:50 PM
The CCT is probably installed fine (hard to mess that up) but it does sound like you have a bent valve (from the earlier one failing).
Old May 1, 2010 | 01:57 PM
merlyn's Avatar
what should I do step by step to verify this???????Thank you!
Old May 1, 2010 | 02:21 PM
Remove the spark plugs, and do a compression test.
thedeatons
Jun 21, 2015 09:11 PM
snakeman34
Mar 26, 2007 08:46 PM
vtrlvr
Feb 24, 2007 04:13 AM
Speed_Demon
Feb 17, 2007 05:57 PM
DaxMiddler
Apr 28, 2006 03:22 AM
