Typical n00b question
OK, I searched. Really I did. Here's the deal. My SH is a work in progress- it needs CCT and R/R and other stuff before I'll ride it. It also needs new sprockets and chain. I have them already, they came with the bike, new in package. The chain is a one-piece unit, with no master link.
So I'm looking at the bike and wondering how much stuff has to be unbolted to get this chain loop installed. One minute, it looks simple, and then I start noticing other things that are in the way.
What's the deal here??
TIA
TIA
Oh yeah, and the swing arm. the chain goes around the left singarm mount and with out the chain being split there is no way to get it into place aside from removing the swinger.
Like crux said. Sprocket cover leave the clutch slave cylinder bolted into this. Don't remove it. Then chain guard. You don't even have to remove the whole rearset either, just the shifter arm and lower bolt on it. Weird that you have a chain shipped already in a loop, but good luck!
The chain can go around a stock swingarm without taking it off. You don't even have to take the wheel off (although you will anyway if you're putting on new sprockets).
I am just going to stop talking today, apparently I'm just all around wrong right now.. but i guess if you run the chain down the swinger you wouldnt have to. good to know.
I normally don't answer question not asked.,, and many above did a good job of answering his specific question BUT..
To the OP.. unless you just have an overwhelming desire to remove the swing arm and associated items to install a endless link chain..
Perhaps instead purchase rivet style masterlink and rivet tool..both can be had for under $40, and then you'll have a nice new tool to add to your collection.
Hahaha, you're on a roll, though! Maybe the European model is different
No the Swingarm can remain in place, it's the gear selector rod and the rearset hex bolt and spacer that gets in the way
Haha, yeah I've been having brain farts lately.
And on this I was pretty sure I had looked at it and didn't think it would come off with out taking the swinger loose but I guess it could have. Not like I was going to reuse the chain anyways so I didn't care the least bit to have to cut it.
BOTH swingarms??? That is not acceptable.
1998 Superhawk for sale. 3rd or 4th owner, no upgrades other than aftermarket mufflers.
Will consider adopting out to a "forever" home, has special needs.
Hawk is paraplegic, wings are clipped and it is unable to move on its own power.
