Trip meter goes zero...
Old Aug 9, 2005 | 07:13 AM
roadrun_fr's Avatar
roadrun_fr
Re: Trip meter goes zero...
should be a condensator ... but not sure ...
You could install a sigma speedo for about 20$ ... that will do the trick and it is more accurate than the stock one ... a lot more with a 15th sprocket ;-)
You can see the difference of precision reading the 2 trips with a 15th sprocket ;-)
Old Aug 9, 2005 | 11:55 AM
kai ju's Avatar
If the odometer resets when you cycle the ignition you either have a low battery charge, a poor battery ground connection or the power line to the odometer is not powered up ( Loose/poor connection at the meter, blown fuse etc. )
First check that the odometer fuse is ok and if so, verify that you have power on the R/G wire to the meter with the ignition off.
The odometer is powered, with the key off, through that circuit.
As far as speedo error is concerned I have had good luck with a Speedo Healer that is adjustable to compensate for sprocket changes, tire wear etc.
Kai Ju
Old Aug 9, 2005 | 03:56 PM
mine did the same thing.... it ended up being a slightly loose negative battery cable....
Old Aug 9, 2005 | 07:48 PM
kai ju's Avatar
English as a Second Language.
I meant tripmeter even though I said odometer.
Sorry 'bout that.
Kai Ju
Old Aug 9, 2005 | 09:09 PM
swordfish's Avatar
where can I get one of those $20 speedo's?
Old Aug 9, 2005 | 09:58 PM
ebay my friend
Old Aug 10, 2005 | 12:45 AM
roadrun_fr's Avatar
roadrun_fr
For sigma, I have found it in a "sport" store where you can buy stuff for bicycle ;-)
It's made for bicycle but can display 200 to 300 km/h :wink:
It's more accurate for the trip but for the speedo the difference is really big !
Stock speedo is very optimistic ....
Old Aug 10, 2005 | 07:52 AM
roadrun_fr's Avatar
roadrun_fr
Great !
Where is that fuse ? With all other ones ?
2armor
Apr 12, 2011 08:19 AM
redman
Jul 26, 2007 03:36 PM
kai ju
Nov 24, 2006 03:27 PM
EngineNoO9
Nov 26, 2005 02:47 PM
Lonewolf
Aug 9, 2005 10:00 PM
