Transmission Problem
Old Sep 9, 2007 | 06:43 PM
mini4m3's Avatar
mini4m3 is on a distinguished road
How much will it cost to replace a 2nd gear synchronizer on a 99 hawk? I'm looking to replace mine cause I'm having some problems with it.
thanks
-kc
Old Sep 9, 2007 | 09:28 PM
Hmmm, um....I hate to be the one to break it to you but motorcycles don't have synchronizers. Describe what it's doing and we'll try to help you out here.
Old Sep 9, 2007 | 09:42 PM
mini4m3's Avatar
lol whups, shows how much of a bike vs. car guy I am.
Its doing what having a broken syncro would do in a car. What I mean by this is that when I try to shift into second gear from first, it either doesn't want to go into 2nd and the shift level will either vibrate (get slapped around) really hard and go in, or get slapped around really hard and won't go in, and will just get in neutral.
This only happens if I am above 3krpm in first gear, and it gets worse as the rpms go higher up.
Now downshifting from 3rd into 2nd it doesn't "slap" or grind but it clicks into 1st very very hard. The bike tells you its in first, and it makes sure you know it.
Any thoughts?
I thought it was syncro, but appearntly bikes don't have them. So is it a problem with my clutch not engaging/disengaging fully? Is it an oil (hyrdrolic/engine) problem?
-kc
Old Sep 10, 2007 | 12:12 AM
Throwedsmurf's Avatar
Throwedsmurf is on a distinguished road
This is a common problem with the SH. Do a search to find out what some ppl have to to help with the shifting. I'm too lazy to do the search for ya and too cheap to fix mine. Sorry lol
Old Sep 10, 2007 | 07:05 AM
mini4m3's Avatar
It's totally fine, I didn't know it was common. Mmm search time.
Old Sep 10, 2007 | 07:09 AM
andy9743's Avatar
if you find something post it up i'm having the same problem and couldn't seem to find anything...i'm search retarded
Old Sep 10, 2007 | 07:17 AM
mini4m3's Avatar
https://www.superhawkforum.com/forum...t=transmission
something along the lines of this
Old Sep 10, 2007 | 02:11 PM
I think what might be happening is you're not giving the shifter it's full throw on upshifts. Try adjusting the lever down. There are two locknuts on the linkage. Loosen them (one is reverse threaded) and rotate the link to move the lever up and down to fit you.
Old Sep 10, 2007 | 04:43 PM
RK1's Avatar
RK1
mini4m3;
The 1-2 shift is something a lot of VTR owners complain about. It was annoying the hell out of me on mine until I stopped using 40 weight oil and switched to a SG/JASO MA 20w50 motor oil. The problem flat out went away.
Honda approves of 20w50 down to freezing. My 1-2 shift now snicks just like the rest of my upshifts. I don't know why it made such a difference but at least on my bike it was like night and day.
Old Sep 11, 2007 | 10:11 PM
mini4m3's Avatar
Thanks guys, I'll check the link first (I am almost a foot taller than the previous rider, so maybe). Then I was gonna do a oil change. I'll let you guys know what the results are asap.
iracebikes
Nov 1, 2012 02:18 PM
RCVTR
Nov 1, 2007 04:35 PM
RCVTR
Oct 28, 2007 06:30 PM
zenbone
Dec 29, 2006 10:21 AM
