TPS Jumper Leads
Old Dec 30, 2017 | 04:11 PM
TPS Jumper Leads
Because you can never check your TPS ohm setting often enough. Made a jumper with a matching connector for the TPS.
Actually I want to experiment with other settings than the current 497 ohm. Seems I've read somewhere that for high altitude there is some benefit to a bit more advance. Understanding that the starting point is the only thing that changes.
Old Dec 30, 2017 | 06:38 PM
Why doesn't this have a rheostat and a digital readout?
Old Dec 31, 2017 | 08:39 AM
Was just thinking that... if you really want to experiment make a bypass with cables long enough to reach bars, take the OHM reading digital leads all the way to the TPS though so you do not get false readings by taking measurements at the adjuster.
And not need for a rheostat , a potentiometer is all thats needed with the very low wattage this circuit has.
Old Dec 31, 2017 | 10:46 AM
Yes, a pot would be more appropriate, but one just doesn't get the opportunity to use rheostat in every day conversation enough.
superchickencornermonster
Jan 9, 2012 05:40 AM
Sprayall
Apr 6, 2010 05:25 PM
Dave Wicks
May 6, 2009 08:07 AM
Anto
Sep 11, 2007 12:14 AM
Zedicus
Mar 12, 2007 11:09 AM
