Tire pressure
Old Mar 17, 2008 | 08:15 PM
happytrack44's Avatar
WERA #44
Tire pressure
I have spent some time reading up on tires in this forum, but have seen little about what pressures you guys run.
The last two crashes I suffered thru were due to bad tire gauges and wrong pressures. 1- Too much at Kershaw in practice and lowsided on the tight turn going onto the front stretch. 2- too much on the new years ride and lowsided at the top of squirrel spur in an easy sweeper.
Stick boy, the Bridgestone tire guy told me I should be running about 30- 32lbs at the track, depending on temp. When I ran that at the track, no troubles.
What do you guys run on the street? I really want to know about the Michelin tires cause I'll be getting them next.
Thanks, Rob
Old Mar 17, 2008 | 08:31 PM
Jeepingoose's Avatar
Jeepingoose is on a distinguished road
I run about 40-45 front and around 35-40 rear
I like the harder feel though
Old Mar 17, 2008 | 08:48 PM
Death Cattle's Avatar
i always do about 2 lbs. less in the front and 4 lbs. less in the back. (i cant remember what the recommended amounts are). that seems to work really good for me. once they heat up they get up around the recommended amount.
Old Mar 18, 2008 | 12:22 AM
RK1's Avatar
RK1
I think lower pressures might work fine on a smooth, high speed race track. On the street I run 40r and 35f. I found running at or near max gives me better suspension compliance over freeway expansion joints, bumps and potholes. Also results in longer tire life and better fuel mileage.
Old Mar 18, 2008 | 08:40 AM
trinc's Avatar
race, trackday, street tires are all different. each manufacturer is a little different. it's best to talk to the track tire vendor for a good starting point.
that said.... i run pirelli dragon supercorsa SC2's
i'm normally always around 30 psi cold . a bit less if it's colder, a bit more in summer. once the weather warms to run a fast pace the rear is 2-3 psi lower than the front.
at the track: i want to see 3-4 psi change cold to hot. if i'm under i lower the psi ... if i'm over 4 psi change i add a little air.
tim
Old Mar 18, 2008 | 12:00 PM
Also have to keep in mind, my tires are ALWAYS warm just about here...
So my "cold" pressure is just about what everyones warm one is normally
Old Mar 18, 2008 | 01:50 PM
Hotbrakes's Avatar
30-32 Front and rear...Michelin Pilot Race
Old Mar 21, 2008 | 07:48 AM
J.J.'s Avatar
J.J. is on a distinguished road
I run 30-32 front and about 25 rear. The lower rear tire pressure allows for a larger contact patch and a more stable ride when riding on one wheel. Not that I'd condone that sort of thing...
Old Mar 21, 2008 | 10:28 AM
Thumper's Avatar
Sheeeessss,
Some of you are riding on rocks hard tires, you really need to drop those pressures some and let the tires do the work they were designed for.
Cold Tire Pressures
VTR Street:
Front 34-36
Rear 33-34
VTR Track Day:
Front 31-32
Rear 30-31
SuperMoto CRF450R (120/160 Tires)
Street/Track Day
Front 22
Rear 20
Old Mar 21, 2008 | 11:34 AM
Damn, i thought they were higher than that... guess i better go let out some air of the back... and not fill the front as high today
Old Mar 22, 2008 | 09:34 AM
doggerman's Avatar
doggerman is on a distinguished road
I run Metzlers.I've gone as low as 28 But generaly have settled on 32-36.I eat tires up and pointlessly whine about it.There was a shop I used to go to that suddenly had new owners.I was whineing again about it as they put new tires on.The tech guy said he ran 40 lbs on his race bike,all right I said i'll give it a try.that lasted maybe 30 miles,it was freaky.I suppose it works fine on his electra glide race bike.
hawkbill
Jul 20, 2007 07:14 AM
Randman
Jun 27, 2007 01:17 PM
CNI Dawg
Jan 1, 2006 10:02 PM
pickle.of.doom
Aug 26, 2005 04:53 PM
blokeontheend
Jun 20, 2005 05:58 AM
