Timing
Old May 4, 2013 | 11:56 AM
Rebirth98's Avatar
Rebirth98 is on a distinguished road
Timing
Ok so I believe I have a cct issue, have the bike down to removed valve covers.
1. is there anyway to check timing with valve covers off and markings on each cam sprocket? I have no clue where to go from here
2. Is there anyway to gauge damage to internals without taking the heads off?
- I am looking to plug and play with new or rebuilt heads
3. If it comes to the point where I need to to remove each head to check internals, The bolt on the outside of the head and I see another on the inside, what others need to be removed to remove the head?
4. What am I looking for internally to say still good or no good?
Thanks
Old May 4, 2013 | 12:06 PM
Wicky's Avatar
Check timing by following the CCT replacement procedure for finding TDC and the alignment for the cams for each pot in the Knowledgeable Base. You'll need to access & remove the alternator timing cover bolts.
And measure valve clearances and if any are way off then that's the sign of valve damage.
Old May 4, 2013 | 12:13 PM
Rebirth98's Avatar
Well I am trying to add a picture but havent ever done so, but on closer inspection of the cam chain one side is aligned and the other is riding above the grooves a bit. after reading cct replacement how do I get the chain back into the grooves?
Old May 4, 2013 | 12:27 PM
Rebirth98's Avatar
where exactly can I find this timing hole?
Old May 4, 2013 | 12:51 PM
Wicky's Avatar
Ronayers.com Microfiche Honda>Motorcycle>1999>VTR1000F>ALTERNATOR
No. 9 is the cap through which you see the timing marks on the flywheel and remove no. 10 to turn the crank round. If you haven't already done so remove the spark-plugs to make turning it over easier.
superchicken
Dec 13, 2007 11:50 AM
superchicken
Oct 8, 2007 09:56 AM
cliby
Mar 1, 2007 09:55 AM
ATLSHawk98
Jan 5, 2007 08:22 PM
dustinwild
Jun 16, 2006 07:36 PM
