Is there an easy way?
Old Mar 16, 2010 | 05:49 PM
98ILVTR's Avatar
To adjust the fuel screw/pilot screw without taking the whole carb off again? I have taken the carb off a lot in the past 2 weeks, probably so much that I could do it in my sleep, but it would be nice to not take off the airbox, etc...
Old Mar 16, 2010 | 06:39 PM
uchi's Avatar
depends how big your hand is. when we did my carbs john was able to shove his hand under them and adjust them with the little tool. its tight but he made it work.
Old Mar 16, 2010 | 06:41 PM
Killemall's Avatar
I don't think so. The only carbs adjustment you could do on-the-fly is the A/F mixture but you got to shell the money for a Flo-commander.
Old Mar 16, 2010 | 07:17 PM
slo1's Avatar
slo1 is on a distinguished road
That's my method as well
Old Mar 16, 2010 | 07:19 PM
98ILVTR's Avatar
Man, thats a tight squeeze, even with the PAIR Valve gone. I'll have to see if I can do it...
I also found this, its cheaper than a Flo-Commander...
http://www.motionpro.com/motorcycle/partno/08-0119/
Old Mar 16, 2010 | 07:21 PM
trinc's Avatar
you can buy a right angle screw driver for $25 then remove the honda D screw and dremel a slot in it. or buy the motion pro tool for $80 and bitch that their D bit sucks and remove the D screw and dremel a slot in it... then use the motion pro flat blade bit.
tim
viperkillertt
Jul 30, 2010 08:27 PM
CentralCoaster
Mar 18, 2009 04:45 AM
rbrais
Oct 7, 2008 11:43 AM
SuperHawkins
Oct 16, 2007 04:15 PM
zimm
Sep 27, 2006 12:02 AM
