temp gauge and rad fans
Old Nov 26, 2012 | 08:15 PM
Ryder3610's Avatar
Ryder3610 is on a distinguished road
I just want to throw this out , to see if it has happened to anyone and to see what it is, i had recently took a cover off to fix a crack in it, when i put it back together the temp gauge had stopped working and my rad fans wont come on. So it has been sitting, any info will be helpful and appreciated
Old Nov 26, 2012 | 10:53 PM
Wicky's Avatar
See if you knocked and dislodged a connector nr or on the radiator when replacing the fairing.
Old Nov 26, 2012 | 11:00 PM
saige's Avatar
the boss
+1 on what wicky said.
plus,check to make sure your rads are completely full,if the water is low,it wont make contact with the sensor and wont turn on.
check the wires on the thermostat and on the front and back of the right hand rad.
Old Nov 27, 2012 | 06:25 PM
Saige is right
Yeah it is the fan switch at the aforementioned top rear of the right rad. It just grounds the fan at 100*, the wire just plugs onto it with a blade connector.
Old Dec 1, 2012 | 06:37 PM
Ryder3610's Avatar
Ok, thank guys i really appreciate it
jack smith
Sep 13, 2012 10:16 AM
evines
Jan 30, 2012 05:28 PM
intoxxx
Nov 8, 2011 02:22 PM
bibblescakes
May 3, 2011 09:11 PM
joshuatest
Jun 26, 2010 02:52 PM
