temp gauge and rad fans
I just want to throw this out , to see if it has happened to anyone and to see what it is, i had recently took a cover off to fix a crack in it, when i put it back together the temp gauge had stopped working and my rad fans wont come on. So it has been sitting, any info will be helpful and appreciated
See if you knocked and dislodged a connector nr or on the radiator when replacing the fairing.
+1 on what wicky said.
plus,check to make sure your rads are completely full,if the water is low,it wont make contact with the sensor and wont turn on. check the wires on the thermostat and on the front and back of the right hand rad. |
Saige is right
Yeah it is the fan switch at the aforementioned top rear of the right rad. It just grounds the fan at 100*, the wire just plugs onto it with a blade connector. |
Ok, thank guys i really appreciate it
