strange electrical event
Old Feb 2, 2013 | 10:47 AM
twist's Avatar
Here is a new one for my VTR. yesterday I went for a ride, I stopped for fuel. Bike was running perfectly. I shut the bike off the way I always do, with the key. I filled up, like always. I started the bike up and all the setings were zeroed out. Both odometers and the clock were re-set to zero. The bike still runs perfectly but I am left baffled over the event. What happened? Anyone have this happen to their Hawk?
Old Feb 2, 2013 | 12:22 PM
cybercarl's Avatar
Weird
Does this mean your Hawk has zero miles on it now, high re-sale value. Or it just the one that you can reset anyway.
Old Feb 2, 2013 | 02:48 PM
Hmmm... that is weird, never heard this before... Did you do any electrical work recently?
Old Feb 2, 2013 | 02:53 PM
PUSHrod's Avatar
Was there a cell tower near by?
The parking lot where I work is next door to one with a maintenance station and when they have a power spike or some sort of failure all the radio presets in my car zero out along with the electronic trip meters.
A weird PITA.
Old Feb 2, 2013 | 03:21 PM
twist's Avatar
Originally Posted by cybercarl
Weird
The odometer is still reading true mileage but both trip meters were zeroed out as well as the clock. I haven't done any electrical work on this bike. No cell tower near that I'm aware of. Looks like I have a short to find.
Old Feb 2, 2013 | 03:29 PM
thetophatflash's Avatar
R/R precursor?
Old Feb 2, 2013 | 04:24 PM
Sounds like the battery voltage dropped when you started the bike.
Now you just to figure out why. It does sound like the R\R issue but do all the tests and go from there. What is the battery voltage now?
Old Feb 2, 2013 | 07:06 PM
Squid's Avatar
I have that problem. Everything but the actual Odo resets. What I have found is that when the battery is low on CCA (Cold Cranking Amps) it will take all the juice the battery has to start, therefore clearing out the all the non stored data. As of now, my CCAs cant even turn the bike over, But durring the summer every now and then during start up when a piston would hit TDC the starter would struggle to push past TDC and used the extra voltage of the battery to "get over the hump" so to speek.
Old Feb 3, 2013 | 12:17 AM
Usually a warning sign to look at the R/R and corroded wiring... The battery isn't charging fully...
Old Feb 3, 2013 | 05:10 AM
Squid's Avatar
Thanks Tweety, I thought I just had a battery that was going bad this whole time.
Old Feb 3, 2013 | 09:08 AM
twist's Avatar
I stand corrected, I replaced the OEM R/R when I bought the bike with a brand new R1 unit, so I have done electrical work. I need to check voltage now since that was brought up. When it happened, I had been riding the bike for a while so it was hot, that's to say normal operating temp. I think it's the battery. Maybe time to finally get one of Jamie's battery packs. Test first tho, I don't like replacing parts that don't need it just to find a problem. Gotta remember, start with the dumbest, most simple thing first.
Old Feb 3, 2013 | 01:24 PM
If the R1 unit is a Mosfet one, it's unlikely to fail that soon (six months?), so I'd say you have a corroded wire/connector somewhere...
You should have 14.3-14.7V at all times (check idle, 3k and 5k rpm) if it's Mosfet, and possibly as much variation as 13.8-14.8V if non-Mosfet... If it's anything other than that, there is something amiss, either with the R/R or the wiring... Especially bad if it's at any time 15V or above, but dropping below 14V means insufficient charging...
And if have that voltage, and your battery still isn't charging, THEN it's the battery going bad/old...
Old Sep 8, 2015 | 06:36 PM
thedeatons's Avatar
I just had this same thing happen this morning. 50 degrees out and the bike was slow to turn over, then i noticed the clock and trip meter was reset...
The battery is quite a few years old, like 4 or 5 i think... May be looking at a new one next year...
(ZX10R mosfet r/r is installed)
James
Old Sep 8, 2015 | 08:40 PM
Cadbury64's Avatar
VTR virgin
I had this happen on my VFR. Started fine cold, then stumbled a bit re-starting after a fuel stop, and the clock/trip reset. I put in a new battery and all has been fine ever since (15000km). I also fitted a voltmeter at the same time so I could get some forewarning if the R/R was crapping out but it is perfect (13.8v all the time) so my problem was just an ageing battery.
8541Hawk
Jun 2, 2010 08:40 AM
Stevebis1
May 27, 2010 10:12 AM
thefauxnarchist
Feb 11, 2009 09:05 PM
adowdell
Apr 23, 2007 08:44 PM
jb
Aug 8, 2004 12:47 PM
