strange electrical event
Here is a new one for my VTR. yesterday I went for a ride, I stopped for fuel. Bike was running perfectly. I shut the bike off the way I always do, with the key. I filled up, like always. I started the bike up and all the setings were zeroed out. Both odometers and the clock were re-set to zero. The bike still runs perfectly but I am left baffled over the event. What happened? Anyone have this happen to their Hawk? :confused:
Weird :confused:
Both odometers and the clock were re-set to zero. (:-}) |
Hmmm... that is weird, never heard this before... Did you do any electrical work recently?
Was there a cell tower near by?
The parking lot where I work is next door to one with a maintenance station and when they have a power spike or some sort of failure all the radio presets in my car zero out along with the electronic trip meters. A weird PITA. |
Originally Posted by cybercarl
(Post 348661)
Weird :confused:
Does this mean your Hawk has zero miles on it now, high re-sale value. Or it just the one that you can reset anyway. (:-}) |
R/R precursor?
Sounds like the battery voltage dropped when you started the bike.
Now you just to figure out why. It does sound like the R\R issue but do all the tests and go from there. What is the battery voltage now? ;) |
I have that problem. Everything but the actual Odo resets. What I have found is that when the battery is low on CCA (Cold Cranking Amps) it will take all the juice the battery has to start, therefore clearing out the all the non stored data. As of now, my CCAs cant even turn the bike over, But durring the summer every now and then during start up when a piston would hit TDC the starter would struggle to push past TDC and used the extra voltage of the battery to "get over the hump" so to speek.
Usually a warning sign to look at the R/R and corroded wiring... The battery isn't charging fully...
(Post 348678)
(Post 348678)
If the R1 unit is a Mosfet one, it's unlikely to fail that soon (six months?), so I'd say you have a corroded wire/connector somewhere...
You should have 14.3-14.7V at all times (check idle, 3k and 5k rpm) if it's Mosfet, and possibly as much variation as 13.8-14.8V if non-Mosfet... If it's anything other than that, there is something amiss, either with the R/R or the wiring... Especially bad if it's at any time 15V or above, but dropping below 14V means insufficient charging... And if have that voltage, and your battery still isn't charging, THEN it's the battery going bad/old... |
I just had this same thing happen this morning. 50 degrees out and the bike was slow to turn over, then i noticed the clock and trip meter was reset...
The battery is quite a few years old, like 4 or 5 i think... May be looking at a new one next year... (ZX10R mosfet r/r is installed) James |
I had this happen on my VFR. Started fine cold, then stumbled a bit re-starting after a fuel stop, and the clock/trip reset. I put in a new battery and all has been fine ever since (15000km). I also fitted a voltmeter at the same time so I could get some forewarning if the R/R was crapping out but it is perfect (13.8v all the time) so my problem was just an ageing battery.
